AC UNIT
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by C15-cat, Jul 3, 2026.
  1. C15-cat
    C15-cat Bobtail Member
    03 peterbilt 379
    C15 Acert
    Ac in cab works great.
    Ac unit in bunk blows warm air.
    Blower works.
    Directional works.
    Switch in cab for sleeper blower works.
    Any direction would help thanks
  3. Concorde
    Concorde Road Train Member
    5,862
    20,935
    Jun 29, 2016
    West Melbourne Florida
    Blend door is my guess. Test the actuators, remove them and manually test the ease of each door..one may be binding up.
    Got the same issue with my 2023 389..blend door in cab not working properly..actuator isn’t strong enough to move one of the doors..
    You got the same deal in your SB
  4. DUNE-T
    DUNE-T Road Train Member
    7,094
    17,295
    May 10, 2015
    Detroit, MI
    Hot/cold valve or switch
  5. C15-cat
    Dise the Truck have a bkend door up front for the sleeper avmc
  6. Concorde
    5,862
    20,935
    Jun 29, 2016
    No it doesn’t.
    Mine actually has its own heater core and ac condenser? In the bunk.
    I probably shouldn’t be trying to compare my truck to yours, I’m sure things have changed over the years. To me it just sounds like a blend do door not closing.
    I recently woke up to a nice cool sleeper and when I opened the curtain it was 200 degrees in the cab, lol
    Deere hunter and BoxCarKidd Thank this.
  7. wore out
    wore out Numbered Classic
    18,168
    230,054
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Some Peterbilts have a solenoid that lets Freon through the rear EVAP and expansion valve. It’s controlled through the bunk heat A/C switch. I’ve got 2 the exact same year model. Both 379 one has it and one doesn’t
    Rideandrepair and Deere hunter Thank this.
  8. Raffito
    Raffito Light Load Member
    93
    59
    Aug 25, 2019
    Ingram, TX
    One thing you can do is a pinch off plier and pinch the heater hose. That way you know if it the heater valve or blend door. It also can be low on freon, hook up the a/c gauges and check it.
    Rideandrepair Thanks this.
