Aftertreatment Fuse Keeps Popping when I hit a bump.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Lookunderthetruck, Oct 15, 2021.
  1. Lookunderthetruck
    Lookunderthetruck Bobtail Member
    27
    8
    Nov 18, 2020
    Hello-
    Fuse L8 (aftertreatment) keeps blowing whenever I hit a bump.
    I have not been able to find any skinned, or broken wires, etc. This seems like the obvious, or most likely cause, unless I've overlooked something.
    Any suggestions on where exactly I should be looking. Could the bump in the road (no pun intended!) be coincidence and it's actually a faulty component within the system overloading?
    Thanks in advance for any ideas on this.
    Should be simple, right? Not so much.
  3. Lookunderthetruck
    27
    8
    Nov 18, 2020
    Changed the wire harness to the pump. Now the fuse blows without hitting a bump.
    Heavyd- you're an electrical whisperer as far as I'm concerned- any ideas on this fuse?
    I don't have access to the Davie program so I'm going in a little (a lot) blind.
  4. Goodysnap
    Goodysnap Road Train Member
    2,626
    6,005
    Jul 12, 2017
    Please share last 8 of VIN
  5. Lookunderthetruck
    27
    8
    Nov 18, 2020
    Goodysnap! I didn't see this until now. It just so happens I've just reached out to you via a different post altogether. I'll get that VIN ASAP. I'm not with the truck now. Please disregard my reply to that other post. It was such a pleasant surprise seeing you here. Thanks!
    Goodysnap Thanks this.
  6. Lookunderthetruck
    27
    8
    Nov 18, 2020
    Oops- I'll send it over to your email.
  • Draft saved Draft deleted
