AG100 Bushing replacement
Discussion in 'Kenworth Forum' started by sorefoot, Aug 14, 2026.
  1. sorefoot
    sorefoot Bobtail Member
    7
    12
    Mar 31, 2018
    I've seen posts about using a jack between the tires on other Airglide suspensions to separate the axles a little and replace the stabilizer bar bushings at the pedestal. Will this work on an AG100 as well? I'm assuming the biggest challenge is freeing up the bolts holding the caps on? Thank you.
  3. OLDSKOOLERnWV
    20,081
    303,186
    Not hard actually. I’ve replaced mine twice.
    I find it is easier to put a jack under the rear of frame by the mudflaps, lift the frame to remove the weight off the air bags a little, especially if you don’t have a dump valve for the bags. Make sure to chock the steer axle!!
    Once you get the bolts out and remove the caps release the park brake if you have maxi’s on both drive axles.
    I use a 4’ lever / pipe and put it up under the front of the rear drive tires and force the tires back a little, you can then push the bushing inward till it clears the mounting area.
    Bushing is split on one side so just open it up and remove from the torsion bar.
    Set the new bushing around the torsion bar and just force the tires backwards once again so you can slide the bushing back into the mounting area. Once again…. Chock the steer tires, having the park brake released will make it much easier since it allows the tires to rotate just a little.
    Having the frame supported is your friend, along with dumping the air bags. If you don’t have a dump valve just jack the frame up a little more, less pressure in the bags will make your job much easier…..
    Edit: When you do the front axle force the front drive forwards.
    Rear axle backwards.
    And make sure the bolts are out on both sides….
  4. sorefoot
    7
    12
    Mar 31, 2018
    Wow. Thank you! Some people respond on internet forums and it's clear they know less about the topic at hand then I do. Every once in a while, someone comes along that restores my faith in getting free advice on the internet and today, it was you!! Thank you for a very detailed answer, you've given me hope! I don't live in the salt belt so I'm really hoping the bolts won't be impossible.
    Thank you!
  5. OLDSKOOLERnWV
    20,081
    303,186
    You’re more than welcome.
    I spent 18 months rebuilding my W9L bumper to mudflaps. The picture below is from that time period about 11 years ago.
    Notice how I have a heavy jack stand under the frame rail? I was replacing all the air bags, but I used the same support on both frame rails when I replaced the torsion bar bushings.
    Chock front steer axle
    Support the frame
    Empty the air bags
    Pry the rear drive backwards
    Front drive forward
    That was the simplest way I found myself.
    Holler if you need anything…..
  6. sorefoot
    7
    12
    Mar 31, 2018
    Perfect. Mine is a straight truck so the frame doesn’t bend down at the end like yours for the fifth wheel. I’ll just have to use some blocks or something to get high enough but everything else is straight forward. Wife has the truck on a fire a few hours from home right now. I’m hoping to get it knocked out as soon as she demobilizes off that one and before the next dispatch. Thanks again.
    Magoo1968, OLDSKOOLERnWV and Oldman83 Thank this.
  7. OLDSKOOLERnWV
    20,081
    303,186
    Your bolts look pretty clean compared to what mine were, I couldn’t even see them.
    Spray some penetrating oil on them were they go through the aluminum, and after you take the nuts off you may just have to use the impact hammering back and forth to loosen them. Then again they may come right out….
