Air bags to high, is there a way to adjust so it rides right?
Discussion in 'Experienced Truckers' Advice' started by OldeSkool, Apr 25, 2019.
  1. OldeSkool
    OldeSkool Road Train Member
    1,257
    2,746
    Jul 17, 2018
    When loaded my truck air bags are nearly maxed out on height. When empty it rides about right. Can I adjust this or does it sound like a different problem?
  3. Steel Tiger
    Steel Tiger Road Train Member
    2,665
    3,221
    Jun 6, 2012
    Orlando, FL
    Sounds like your leveling valve needs adjusting
    KB3MMX and OldeSkool Thank this.
  4. AModelCat
    145,331
    What do you mean maxed out on height? Did you measure and compare the ride height loaded and empty? The bags will inflate as weight is added but the height should stay the same.
    KB3MMX, Dino soar and OldeSkool Thank this.
  5. starmac
    starmac Road Train Member
    6,642
    12,524
    Apr 11, 2019
    Fairbanks Ak
    Are you sitting on level ground??
    If your drives are on somewhat level ground, the height of the bags should not change, if they do it is not an ajustment problem, possibly a valve problem.
    OldeSkool Thanks this.
  6. OldeSkool
    1,257
    2,746
    Jul 17, 2018
    Well I never noticed it, but had an older trucker point it out and since then it always does it. When empty about a hand width of silver metal shows at bottom of bag, when loaded it's a lot more probably twice as much metal showing.
  7. mustang190
    mustang190 Road Train Member
    2,722
    5,817
    Jan 18, 2011
    Florida Panhandle
    Take it to the dealer. Do not adjust the air bags yourself. If there is any driveline damage, you own it.
  8. Dino soar
    Dino soar Road Train Member
    4,589
    21,825
    Dec 8, 2017
    Probably leveling valve.
    Fix as soon as possible or you will destroy your universals.
  9. striker
    striker Road Train Member
    5,906
    6,186
    Aug 8, 2009
    Denver, Co
    leveling valve, fairly common item to fail, maxed out airbags is an accident waiting to happen, if a bag blows, it can cause loss of vehicle control and a rollover.
  10. Pepper24
    Pepper24 Road Train Member
    1,809
    1,269
    Dec 3, 2010
    You can check your ride height to see if it’s right.While bobtail measure from ground to bottom of frame rail between tandem then measure from ground to center of axle outside of wheel subtract the 2 that’s your ride height.For example if frame measures 25 and axle is 10 your ride height is 15 inches.You can simply call the dealer of the make with the year and model they will tell you what number it should be.
