Air brake issue, hearing a leak while pressing the break peddle.
Discussion in 'Questions From New Drivers' started by Chipperrr, Jan 22, 2021.
  1. Chipperrr
    Chipperrr Light Load Member
    55
    9
    Nov 27, 2018
    OK so with the truck parked. I can apply foot brake and I hear air leaking Heavily but can't tell words coming from?
    Any ideas?
  3. 50WT
    50WT Heavy Load Member
    803
    5,863
    Dec 26, 2015
    Bad brake can , or busted line.
    Bean Jr. Thanks this.
  4. kemosabi49
    10,008
    41,489
    Jan 13, 2013
    SW Arkansas
    Jam a stick or something between your seat and the brake pedal, then get out of your truck a listen.
  5. Dale thompson
    4,634
    35,654
    Nov 20, 2013
    commerce twp,mi
    You now get to play elimination logic. When you apply brakes it pressurizes the service brake system. This is all hoses valves and canisters. Start big is it the tractor or trailer. My second move would be to inspect the brakes looking for signs of inoperative wheel (rust on the drum is the biggest clue) hole in air line or bad diaphragm are your most likely suspects.
  6. 062
    062 Road Train Member
    5,852
    31,733
    Oct 20, 2013
    With the knob pushed in right?
  7. AKDoug
    AKDoug Medium Load Member
    323
    800
    Mar 21, 2018
    If parking brakes are released, the first place I look is the blue line to the trailer.
  8. God prefers Diesels
    4,198
    22,246
    Jun 26, 2020
    South Texas
    If you get out of your truck with the knobs in, don't forget chocks. Been enough threads recently with truckers getting ran over by their own equipment. Even if you have the brake pedal depressed with a board or something, you don't want to be under a tire when it slips off the pedal.
