Air Flowing When Holding Brake Pedal
Discussion in 'Questions From New Drivers' started by PianoManCJS, Sep 26, 2026.
  1. PianoManCJS
    PianoManCJS Medium Load Member
    439
    445
    Jan 13, 2025
    This trailer has been to a mechanic once or twice and the issue still persists. So before getting a mechanic to look at it again I'd like to poke around and ask:
    When the brake pedal is pressed with the red valve in, air starts hissing through the red trailer dashboard protection valve. I had a helper hold the brake pedal down and I got underneath the trailer. I could hear flowing either into or out of emergency (red line) air tank. I don't hear air coming or leaving service (blue line) air tank because the sound from the red tank is too loud. I see the blue line from the gladhand enter a T joint...one part of the T enters into the service relay valve. The other part of the T has a blue line that goes directly to the emergency relay valve. My only guess is that the air escaping is going through blue gladhand, to the T at the service relay valve, then to the red relay valve, and then into the emergency (red) air tank.
    That or air from the red air tank is traveling through emergency relay valve, through blue hose, to service relay valve, and into service (blue) air tank.
    My question then is, why is there even a blue hose connecting between the service and emergency relay valves? Is that even supposed to be there?
    I've already tried to see if there was a hole in any of the brake chamber diaphrams by disconnecting blue gladhand and pressing in red valve. No air came backwards through trailer blue gladhand. I connected truck red gladhand to trailer blue gladhand and pressed in red valve...lots of air was trying to escape through emergency relay valve on trailer but no air was coming backward through trailer red gladhand. Finally, I tried connecting truck blue gladhand to trailer blue gladhand and disconnect red gladhand and press red valve in and press on brake pedal...no air came backwards through trailer red gladhand.
    It's problematic because whenever the truck is stopped at stoplight with red valve in and brake pedal pressed air starts hissing through dashboard red valve and air starts dropping moderately. In order to combat this I pull red knob only at stoplights and rev up the engine to 1200rpm in neutral just to rebuild air into the truck tank because the emergency tank in the trailer seems to be depleted a tiny bit.
    However, when I did have a helper press the brake pedal with the red valve pressed in and I was underneath the trailer I could hear air flowing into or out of emergency (red) air tank BUT I did not hear or feel it leaking out from anywhere externally...not externally from the tanks, not externally from the numerous hoses, not externally from the relay valves.
  3. PianoManCJS
    439
    445
    Jan 13, 2025
    I forgot to mention that the front emergency air tank has a red hose connecting directly to the rear service air tank. This trailer has been hooked to several different trucks and acts the same everytime and both relay valves have been replaced.
    https://shorturl.at/LMLQw
  4. Big Road Skateboard
    7,999
    46,887
    May 2, 2021
    Can you take some pictures of those valves that will show some more detail? It's hard to make out exactly which valves you have.
    Primarily the left side of the service valve is what I'm needing to see.
    201 Thanks this.
  5. PianoManCJS
    439
    445
    Jan 13, 2025
    I'll try in morning; it's a drop frame trailer and not a lot of crawling room.
    Big Road Skateboard Thanks this.
  6. Big Road Skateboard
    7,999
    46,887
    May 2, 2021
    Hey, I think I misunderstood the problem. I'll watch the videos again when I have better service, but don’t crawl n under it yet.
    I know you said several trucks have had the same problem, but this sounds like a truck issue. I'll holler back when I can watch the videos again.
    Have you tried removing the truck side blue glad and blocking it somehow (another gladhand plugged), then with your red gladhand still attached (or you can block it off too, doesn'tmatter), release the brakes and hit the brake pedal.
    I'm betting you still have the leak.
    Yes, it's supposed to be there.
    And I'm sure you know, but that would be an OOS if you're inspected.
    tscottme Thanks this.
  7. Big Road Skateboard
    7,999
    46,887
    May 2, 2021
    One other thing. Have you opened the valves on the bottoms of the air tanks on the trailer to verify they have what seems like sufficient pressure with the trailer brakes released?
  8. Big Road Skateboard
    7,999
    46,887
    May 2, 2021
    Unless possibly they put the wrong supply valve on, or plumbed it wrong, I'm guessing you either have a restriction somewhere in the supply and no or low air pressure in the trailer air tanks, or a truck issue.
    The red air line from one tank to the other is basically the supply line to the service tank.
    What happens with both brakes released, and you continue holding down the brake pedal?
  9. Ridgeline
    22,863
    126,811
    OK, let's start with stopping calling things by color but by purpose.
    What you are calling red and blue are Supply and Service lines, respectively.
    There is no emergency air tank; there are two service tanks for air supply. The one with the valve attached to it is to ensure there is air going to the parking brakes so there isn't a depletion of air when the brakes are applied with some force. The other is to make sure that the relay valve is properly supplied with air to apply the brakes.
    Now here is the thing: those valves are SR5/SRC7000 (spring brake valve), which is mounted onto the tank, and the other is an ABS module-type valve, maybe an A-18 or MC-30 ABS/Relay valve (black thing on top of the valve says ABS).
    The hose that goes between them is there for balancing between the valves; it is called an anti-compounding line to prevent harsh application of the brake if there is an imbalance and to ensure the valves are regulating the air equally.
    As for your problem, it is for the mechanic to figure out.
    Why?
    Because unless you went to school for this and you try to deal with it on the road, you can cause an accident.
    If the mechanic can't figure it out, it needs to go to a proper trailer shop (manufacturers) and gone through for the entire air system.
    But to add to this, it sounds like one of two issues: one is a split hose, which is causing an air leak (could also be a bad fitting or something like that)
    OR
    A generic valve was used to replace the original valve, and the ports are not the exact same. Many Chinese replacement valves seem to have this issue, even if it is a brand-name part.
    Either way, the trailer should be OOS until it is fixed properly.
    TripleSix, Magoo1968, Judge and 3 others Thank this.
  10. PianoManCJS
    439
    445
    Jan 13, 2025
    Here we go:
    https://shorturl.at/j4soY
    Yes, I will stop referring to things by color, and yes I do want a mechanic to see this, so, I'd like to tell him/her what has been found...if nothing found on my part, then at least describe what's happening when a driver is driving it.
