Air issues
Discussion in 'Ask An Owner Operator' started by JDCUSTOM710kw, May 28, 2020.
  1. JDCUSTOM710kw
    JDCUSTOM710kw Bobtail Member
    Hi, I am driving a truck with air issues. The first is the air dryer won't stop leaking, like continuous, not talking about poping off every 10 seconds. I think the air dryer needs rebuilt. The second issue is the air suspension on the drive axles, when loaded it won't air up all the way, the bags do have some air in them. Any ideas on what to do, thanks in advance.
    Trucking Jobs in 30 seconds
  3. kemosabi49
    5,265
    14,388
    Jan 13, 2013
    SW Arkansas
    Air dryers are not expensive. Get a new one then in the future change the desiccant filter every year or so.
    Can you adjust the height on your air bags at the leveling valve? Is the leveling valve even working? Disconnect the rod and find out.
  4. baha
    baha Road Train Member
    3,400
    1,912
    Jul 25, 2013
    ga
    If the air is not getting much over 90lbs the air bags will not fill up all the way?
    magoo68 Thanks this.
  5. Snailexpress
    1,891
    3,291
    Apr 28, 2014
    Should be fill full as under 34,000 load pressure in bags is around 55 PSI
  6. magoo68
    magoo68 Road Train Member
    2,962
    4,104
    Jun 11, 2011
    st malo mb canada
    Many trucks won’t release air to air bags until tanks are 80 to 90 psi. It’s to preserve air for braking purposes ..
  7. sjcaliguy
    sjcaliguy Bobtail Member
    4
    May 28, 2020
    Can anyone give advice on why my cab and sleeper airbags keep leaking, pinhole leaks
  8. danny23tx
    danny23tx Road Train Member
    1,075
    1,332
    Feb 16, 2016
    Its probably the pop off valve but it's cheaper to buy a new one than rebuild in most cases . You can by pass it but than risk getting moisture in the lines , it's only recommended to get you to your destination and than a shop .
  9. Ridgeline
    15,935
    62,735
    They wear out.
    baha Thanks this.
  10. JDCUSTOM710kw
    Oh I forgot to add, the tank popet valve is popping off every 30 seconds or so at around 150 psi and the bags have air in them just not full with a load on. Air govenor was replaced about 2000 miles ago.
  11. Espressolane
    6,242
    18,502
    It is highly probable that your complete air drier is bad. You may also have some clogged air line, most likely from the compressor to air drier. Part of the reason it is essentially over pressuring the system is the unloader control system is not working correctly.
    A new complete air drier unit is around $200.00. They are easy to replace if you have the correct tools. Should take less than an hour to do.
  • Draft saved Draft deleted
