Air leaking from air tanks even though they are closed .
Discussion in 'Questions From New Drivers' started by Southsidetrucker, Dec 1, 2024.
  1. Southsidetrucker
    Southsidetrucker Bobtail Member
    16
    15
    Jul 6, 2022
    I have a 2015 Freightliner cascadia and when I shut my truck down I can hear air coming from my 2 air tanks under the driver side . They are closed but air is still coming out both tanks . It seems like air is coming from the valve that opens and closes. Are those valves able to be replsced on their own ?
  3. Big Road Skateboard
    6,012
    32,430
    May 2, 2021
    Yes, 1/4" pipe thread. Buy a new valve, put thread tape on the threads, R&R. Very simple fix, and a common failure.
    Drain your tanks first before removing the old ones.
  4. dosgatos
    dosgatos Medium Load Member
    559
    1,218
    Sep 18, 2012
    Keep a sprayer bottle with dishwash soap in the side box. Every truckstop sells little bottles of Dawn. Handy for windshields when the truckstop doesn't maintain the squeegee bucket. Also for finding leaks.
  5. Concorde
    Concorde Road Train Member
    4,507
    16,114
    Jun 29, 2016
    West Melbourne Florida
    Those valves have a name :)
    Why do they call it a petcock?
    Etymology. Apparently from pet +‎ ####, because of its size.
    Oxbow Thanks this.
  6. Ridgeline
    22,307
    115,407
    Why?
    Because it comes from the term Petty valve which was essentially a cone-shaped valve with pressure applied to seal it. Usually, the pressure comes from a spring.
    The word ***** comes from what I was told, a nautical term about ship ballast valves.
    It is as bizarre as jubilee clips, being another name for a hose clamp.
    Or why Canadian Ford Model Ts and other cars used square drive screws but not US cars.
    wis bang and Concorde Thank this.
  7. SomeCanadian
    SomeCanadian Light Load Member
    156
    426
    Nov 11, 2021
    Roberson, inability to use the inferior Philips in Canada.
    (I can’t remember the whole story but it was interesting to listen to) something about patients
    buzzarddriver Thanks this.
  8. Frank Speak
    Frank Speak Road Train Member
    4,490
    13,724
    May 3, 2016
    Seems to be a premature leak. Usually, yer “petcock” doesn’t start leaking until you enter yer more senior years.
  9. Ridgeline
    22,307
    115,407
    Ford had this habit of telling the supplier - you do what we want or you don't sell to Ford. The time savings alone justified the use of the Robertson screw but Robertson said that he can not have the license to make it, which I think was a mistake on Robertson's part, but he could use it for Canadian cars because Robertson's company could supply them consistently.
    Here is the Wikipedia snippet on the issue - The Fisher Body company, which made the car bodies for the Ford Motor Company, was one of Robertson's first customers and used over 700 Robertson screws in its Model T car. Henry Ford, after finding that the screw saved him about 2 hours of work for each car, attempted to get an exclusive license for the use and manufacture of the Robertson screw in the US. He was turned down by Robertson who felt it was not in his best interest and shortly after that, Ford found that Henry F. Phillips had invented another kind of socket screw and had no such reservations. Although the Robertson screw is most popular in Canada, it is used extensively in boat building because it tends not to slip and damage material, it can be used with one hand, and it is much easier to remove/replace after weathering.
    When I got my 1930 Chevy Oshawa-built car, it used the Robertson screws everywhere. It was not a common screw here in the States so I went to Canada and bought a short pallet of assorted screws from a supplier. This was back when Customs was nice people - 1975, so bring it back, it wasn't even questioned. When I was given a model T (pile of parts, actually), it had the same screws so I knew it was Canadian built, and it was confirmed by the wider axles. That car was one of the most dependable cars I owned other than my Prius.
