Air Pressure Won't Build Over 30lbs N14 Cummins
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Catchley, Jan 19, 2025.
  1. Catchley
    Catchley Bobtail Member
    Jan 19, 2025
    Hi.
    I have an N14 Cummins engine in Volvo. It won't build air pressure over 30psi. Replaced air governor, adjusted air governor. I drained the air tanks of moisture, poured airline antifreeze down one of the inlets, banged on the air dryer for the purge valve. Tapped on the side of the compressor. Still nothing. This has happened during a rough cold snap in Chicago.
    Does anyone have any suggestions? Can someone direct me to where the unloader valve and the check valve are on this particular motor?
    Thanks.
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Air dryer is probably frozen. Banging on it won't help. Disconnect the line going into the dryer and run the engine and see if air is coming through. If so, then bypass the air dryer and see if air pressure comes up.
  4. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    My n14's had 2 different types of air compressor. The last one I had the unloader valve was on top of the compressor.
    Remove the intake air line from the air compressor. That's where the unloader valve is.
  5. Catchley
    Jan 19, 2025
    Thanks for your suggestions. I'm going to try to work on it Wednesday when the temperature is a little warmer. I'll write back and let everyone know how it goes.
    Heavyd Thanks this.
