2002 Volvo VNL 780 Air PSI Issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JRK, Aug 1, 2021.
  1. JRK
    JRK Bobtail Member
    7
    picked up truck after having it serviced a
    2002 Volvo VNL 780
    VIN 4V4NC9TJ12N331024
    Engine serial ISX 475HP 14020915
    shop is closed had to drive home with this, there is 115 psi in air tanks , breaks release, air to suspension.
    No Air to Splitter or Cab air bags or to raise or lower suspension or engage rear differential.
    any help would be appreciated.
  3. AModelCat
    145,339
    Sounds like the pressure protection valve is sticking. Probably located on one of the air tanks.
    spsauerland Thanks this.
  4. Team818
    Team818 Medium Load Member
    397
    626
    May 5, 2019
    I hope he can correct that. Wow. The mechanical forces released that Truck to soon. My goodness I hope its doesn't cause a incident on the highway. Might want to U Turn and get back there asap, what if the brakes all apply at the same time..... yikes.
  5. JRK
    JRK Bobtail Member
    7
    i have never heard of that what does it look like
  6. AModelCat
    145,339
    Purpose of the pressure protection valve is to protect air supply for the brakes. All it is is a valve that won't let air flow from the tanks to the air operated accessories until a specific system pressure is reached. Ever notice how once a truck hits about 90 PSI the cab and suspension inflate? That's the pressure protection valve opening.
    spsauerland and Goodysnap Thank this.
  7. JRK
    JRK Bobtail Member
    7
    i didnt know till i was on the way home , no place to turn around. made it home safe and put truck in the air i thought tech may have disconnected or some thing came lose by accident.
  8. AModelCat
    145,339
    Google search " Bendix pressure protection valve" there's a few variations that look different.
  9. JRK
    JRK Bobtail Member
    7
    i have heard of tractor protection valve, i had air to brakes and all air bags just not cab bags suspension and splitter, it is a 13 speed
  10. Team818
    397
    626
    May 5, 2019
    Oh thank the Lord. It made it to your place.
  11. JRK
    JRK Bobtail Member
    7
