Air to Air Transmission Cooler
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gliding ProStar, May 15, 2022.
  1. Gliding ProStar
    Gliding ProStar Heavy Load Member
    830
    5,843
    Nov 12, 2016
    Waxahachie, Texas
    Hey guys! My truck is a 2014 International 9900i Eagle. I have an ISX-15 and it is coupled with the RTLO-18918B 18 speed trans. I wanted to ask if anyone knew what the part number is for the Air to Air Transmission Cooler that will replace the factory Air to Water Trans cooler? Also, if any of you have performed this specific swap did the new trans cooler come with any hardware? Thanks for the help. Y'all be safe!
  3. Magoo1968
    Magoo1968 Road Train Member
    1,904
    4,997
    Mar 18, 2021
    St Malo mb
    I never knew they built such a cooler learn something new everyday . Curious how the concept works.
  4. AModelCat
    145,345
    My 1980 KW has one. Just hangs from the rear cab crossmember, above the driveshaft.
  5. Magoo1968
    1,904
    4,997
    Mar 18, 2021
    St Malo mb
    So it circulates hot air from inside transmission to be cooled by airflow ?
  6. Lexuslane
    Lexuslane Medium Load Member
    495
    1,000
    Oct 22, 2021
    It can’t be an air to air since the trans fluid is in the cooler .
    It’s oil to air .
    Which is very common on most every vehicle with an automaton trans
    some vehicles have them inside the radiator and some of those have an additional oil to air cooler after the rad cooler
  7. kranky1
    kranky1 Road Train Member
    2,253
    8,843
    Sep 16, 2015
    Ontario, Canada
    Any cooler will work. You just have to make up lines with the right fittings and mount it somewhere. I made 2 of mine with the power steering coolers for F450’s mounted on the horse collar under the transmission. Used pieces of aluminum walk plate extrusion for grilles.
  8. Magoo1968
    1,904
    4,997
    Mar 18, 2021
    St Malo mb
    I’ve heard of air to oil and air to water coolers on transmission just can’t grasp concept on air to air .
  9. lester
    2,819
    7,479
    Jan 2, 2012
    NW, Iowa
    It's not air to air. It's oil to air. And you should be able to walk into any decent heavy truck store and tell them you need a oil to air trans cooler. Pretty universal. I removed my oil/water trans cooler and replaced with air cooler. Ran some new hose to where I mounted cooler in front of a cross member. Has to fab 2 very simple and crude brackets
  10. AModelCat
    145,345
    That went completely over my head. Thread title must be mis-typed I'm guessing.
  11. bigguns
    bigguns Road Train Member
    2,846
    6,848
    Jun 13, 2013
    Omega,GA
    I have a picture in my photos if only I knew how to upload it. I buy them from eBay. I’m trying but the pic won’t load to my reply. Hayden oil cooler 1240. Best I can do.
