Air vs Water cooled Tranny cooler
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Slow302, Jul 12, 2018.
  1. Slow302
    Slow302 Light Load Member
    189
    38
    Jul 12, 2013
    MO
    I seen and drove trucks wih both. 07 Century with Detroit 60 and 10 speed Eaton had air cooled, 04 Volvo with ISX and 99 T2000 with 3406E both with 13 speed Eaton and both water/antifreeze colled. 07 Century i anly drove for a months so not much experience or problems. Tranny temp newer climb higher than 200f. On 04 Volvo that i drove for 10 years didnt have any problems but tranny temps were in 200-220s since ISX runs warmer with EGR. Tranny cooler was located in frame, right over tranny. Now on 99 T2000 same setup as Volvo. Tranny temp is 200F on hot day. On 99 T2000 i made all heather hoses with shut off valves and i did some testing. If i shut off tranny cooler antifreeze line, tranny will run 220F on hot day.
    Now im thinkin to retro fit Air cooler and mount it somewhere where is a lot of air passing thru. Is this setup much efficient vs water cooled setup ?
    With Air cooled setup will eliminate mixing tranny fluid and antifreeze due to tranny cooler
    Also who makes good Air cooleer tranny cooler? Part #s would be great
    Thanks
  2. uncleal13
    uncleal13 Road Train Member
    2,266
    2,858
    Apr 9, 2009
    Humboldt, Sk
    It is best if the cooler is mounted out front, the ones mounted above the tranny don’t get enough air flow when climbing long grades in the mountains during a hot day.
    I had a 2006 Century 18 spd with it above the tranny and could see temps over 300 degrees in hard conditions.
    Oldironfan Thanks this.
  3. Slow302
    189
    38
    Jul 12, 2013
    MO
    Was it Air or Water cooled ?
  4. uncleal13
    2,266
    2,858
    Apr 9, 2009
    Humboldt, Sk
    Air cooled
  5. Oldironfan
    Oldironfan Road Train Member
    5,778
    5,389
    May 22, 2017
    Air wins every time. More reliable, runs cooler.
  6. W900AOwner
    W900AOwner Medium Load Member
    655
    1,109
    Jul 2, 2014
    Air cooled for sure. I've had a couple of buddies that had a liquid cooled tranny fail, dumping coolant into the tranny and burned it up badly. Pulled the drain plug to find antifreeze instead of oil in the box. That's an expensive lesson. Air coolers rule.
    Check with the transmission mfgr before eliminating/bypassing the internal liquid cooler system too if you're thinking of switching over. Some of them are bypassed with just a loop from one port to the other, some others you can't just loop them together due to a pressurized pump system internally. Found that out the hard way too.
    Google radiators/charge air coolers/transmission coolers. There's several good suppliers out there that make them.
  7. Slow302
    189
    38
    Jul 12, 2013
    MO
    I have found Eaton part #s for Air cooled setuo? K-1956 for kit and optional filter base S-1404 and filter 17238
  8. KTM042974
    KTM042974 Bobtail Member
    8
    If you have a liquid cooled make sure you check your fluids regularly, found out the hard way on that myself. For me air is the way to go!
  9. Slow302
    189
    38
    Jul 12, 2013
    MO
    Here is finished retrofit air cooled tranny cooler. I coulnt foun better place so i mount it on pass side right in front of fuel tank. Now is time to test it
    Tug Toy and uncleal13 Thank this.
  10. Slow302
    189
    38
    Jul 12, 2013
    MO
    Did some testing. On idle over night temp was 145F vs 180F with. Driving on hot day 96F temp was 180F vs 205F. So there is good temp drop plus no more chances coolant mixing with tranny fluid
    spsauerland and Tug Toy Thank this.
  • Draft saved Draft deleted
