Aluminum drive axle hubs?
Discussion in 'Heavy Haul Trucking Forum' started by W923, Apr 18, 2022.
  1. W923
    W923 Road Train Member
    1,462
    4,561
    Feb 28, 2022
    I recently bought a set of new aluminum conmet uni mount hubs that fit my 46k rears. At $17.50 for the 4 I had to bring them home. I have seen lots of aluminum hubs on lighter spec otr stuff but will they hold together for the kind of abuse that heavy haul can give? Conmet says there rated for 23k axles
    Any experience?
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,856
    Sep 16, 2015
    Ontario, Canada
    Never had a problem with them myself. My trucks run 37,400 to 39,600 on the drives depending where they are, and they’re out in the bush or on industrial roads at those weights on the regular.
    cke and CAXPT Thank this.
  4. goga
    goga Heavy Load Member
    895
    1,586
    Nov 11, 2021
    Earth..
    They would not be rated at 40k if they would not be suited for that.
  5. SmallPackage
    5,988
    19,373
    Dec 20, 2019
    Marion Texas
    All you see down here is aluminum hubs with all applications. Been like that for 50 years since the SQ100 days. Unless you got spokes.
  6. Tom Hank’s Volleyball
    Tom Hank’s Volleyball Light Load Member
    63
    141
    Oct 23, 2021
    How much weight does it save?
  7. Big Road Skateboard
    7,999
    46,881
    May 2, 2021
    Probably 30 pounds roughly, per hub
  8. goga
    895
    1,586
    Nov 11, 2021
    Earth..
    It should be no more than fat, greasy driver vs skinny, slim :D
    cke, Chieftains, CAXPT and 1 other person Thank this.
  9. W923
    1,462
    4,561
    Feb 28, 2022
    Agree but there’s a difference between engineering and reality
    Honestly I am more worried about breaking the drive flange studs out than them not holding the weight
    cke, shooter19802003 and CAXPT Thank this.
  10. W923
    1,462
    4,561
    Feb 28, 2022
    When you’re already a skinny driver you gotta go after something else lol
    I really don’t care about the weight
    Honestly would have used iron hubs but these were to cheap
  11. goga
    895
    1,586
    Nov 11, 2021
    Earth..
    To cut the weight you can always run on half worn tires, half a tank of fuel, take everything out of the cab but driver's sit, put on lighter mud flaps, quarter container of windshield washer fluid, something else to cut?... :D
    PS: I wouldn't worry about them being aluminum, as long as they are rated at the weight you are interested in. Main thing is to have good lubricant and break chambers, so bearings would not get hot and break shoe would not lock.
    cke, Deere hunter, beastr123 and 2 others Thank this.
