Another Coolant Leak!?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, May 5, 2020.
  1. PE_T
    PE_T Road Train Member
    I found a coolant leak under the cab on the driver side in between the driver seat and the sleeper mattress. It’s leaking on top of the fuel tank. Is that a heater core? Both hoses are leaking, so it doesn’t look like the hoses are damaged. This is on a 2014 Freightliner Cascadia DD15.
  3. wtokhi
    wtokhi Light Load Member
    247
    114
    Nov 3, 2017
    yes thats ur heater core, if i were you id change the heater core along with hoses and clamps, if i remember correctly the heater core is accessed from under the sleeper bed
    Rideandrepair and PE_T Thank this.
  4. uncleal13
    uncleal13 Road Train Member
    3,757
    6,199
    Apr 9, 2009
    Humboldt, Sk
    QUALITYTRUCK, Rideandrepair and PE_T Thank this.
  5. PE_T
    Cool! I didn’t think about trying to look it up here.
    Rideandrepair Thanks this.
  6. Rideandrepair
    16,526
    53,944
    Aug 8, 2015
    Same Truck you just flushed and filled? At least you can turn off valve, nothing lost. Just when you thought it was all set for a while.
    PE_T Thanks this.
  7. HoneyBadger67
    2,056
    4,509
    Dec 15, 2018
    Savannah, TN
    One thing I've learned with owning a truck, you're never "all set for a while". As soon as one job is complete, another one makes itself evident.
