any suggestions (brake valve air leak)
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by thecubantrucker, Nov 12, 2019.
  1. truckdriver31
    6,986
    8,340
    Sep 18, 2013
    just use a rubber ban on the trolly valve. push trailer knob in and set truck brake. be on level ground. turn key on. do your walk around then. get psi on tanks until it pops air. then turn truck off
    Rideandrepair Thanks this.
  3. truckdriver31
    6,986
    8,340
    Sep 18, 2013
    if your secondary air gauges goes down. i would put $$$ on the trailer leaking air
  4. thecubantrucker
    thecubantrucker Light Load Member
    138
    82
    Jun 2, 2019
    no I didnt they are connected thr right way
    Rideandrepair and truckdriver31 Thank this.
  5. thecubantrucker
    138
    82
    Jun 2, 2019
    that's my next move today I will be doing that if a chamber is leaking will I be able to hear it ??
  6. truckdriver31
    6,986
    8,340
    Sep 18, 2013
    yes
  7. thecubantrucker
    138
    82
    Jun 2, 2019
    I got to push both valves in right red and yellow then get that rubber band and pull the trailer hand brake and go back there and see
  8. truckdriver31
    6,986
    8,340
    Sep 18, 2013
    no. if you did that. the truck can roll away. truck knob out. trailer knob in. then use rubber ban. trolly valve push down with rubber ban to maybe something like trailer knob
