I've replaced mine recently and already leaking out of the top right corner, same place it was last week, was wondering if this could be a symptom of a bad brake chamber or something pushing air back, I dunno don't wanna keep changing it if it's gonna do same #### thing.
Anyone have issues with volvo air manifold above driver fuel tank?
Discussion in 'Ask An Owner Operator' started by ashtre, Feb 7, 2023.
If you just replaced it, it will have a one year warranty. -
There is a way to fix it so it won't ever leak again.
Plastic line for all the ports.
Compression fittings for each line.
Stub a 1" line on compression fitting
Super glue gel inside and outside of plastic line and shove in port.
Now the whole block has compression fittings. -
The manifold is to supply air for auxiliary things - cab suspension, diff lock, fifth wheel slide, rear air suspension bags. Nothing to do with brakes. If system pressure falls below 20 PSI valve in the manifold will close supply.
