APU's create pollution
Discussion in 'Driver Health' started by George0966, Jan 17, 2011.
  1. George0966
    George0966 Bobtail Member
    27
    5
    Dec 7, 2010
    iowa
    While the use of apu's has many advantages,no one seems to talk about the exhaust coming from those exhaust pipes at the bottom of the trucks.
    Hot air rises and if you are parked next to a truck running one, well where do those "environmentally friendly" units vent to? Right into the bunk area of the truck next to it.
    I,m all for saving fuel ,however I shouldn't have to sleep with those fumes in my bunk. Ideally the wind would carry it away but usually there's someone on the other side.
    Couldn't the manufactures of these machines devise a way to reroute the exhaust, maybe tie into existing truck exhaust pipes and vent into the air above the trucks?
    Breathing those fumes while trying to sleep, cant be healthy.
  3. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    Farting creates pollution also.... But I don't hear anyone talking about that nasty air! And no person deserves to sleep with that air!!!
  4. Jolsen
    Jolsen Heavy Load Member
    951
    272
    Mar 6, 2010
    East of the big crick
    hippies that don't take showers pollute my sinus cavity but I don't see a law forcing them to shower.
    Also you cant route it into the trucks exhaust due to the air pressures when the truck is running it would force air the wrong direction into the apu forcing it to turn backwards the whole time your driving.
    FyI I am sitting on top of my apu and the fumes don't bother me any. Then again if fuel was cheaper I would just idle my big kitty kat on high idle till the cows come home and I don't own any livestock
  5. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    An APU's output is miniscule compared to being parked next to a running truck with a grassburner exhaust system. A few Stevens trucks have just about fumigated me.
  6. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    If a new APU starts to smoke and stink really bad, it probably needs service..
  7. OntarioGuy
    OntarioGuy Light Load Member
    85
    65
    Jan 14, 2008
    Northern Ontario
    Wasn't that years ago, KD Lang talked about all the cow farting? maybe belching?
    I'm not joking.
  8. Injun
    Injun Road Train Member
    8,501
    9,491
    May 15, 2010
    West o' the Big Crick
    I have a Carbon Monoxide alarm in my truck. If it goes off, I'll be pounding on the truck putting that muck out and telling the driver to get out, shut off the APU and air his or her truck out. If I'm getting it in mine, you can be sure it's filling theirs as well.
    I have parked with a lot of APUs next to me and never had that alarm sound off.
  9. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    you can tie the apu into your stack you just need to install a check valve on the apu..
    or you can run a 1-1 1/2 pipe next to your stack for the apu
    or run a flex pipe to the back by the mudflap
  10. scottied67
    scottied67 Road Train Member
    10,818
    12,622
    Mar 14, 2010
    california norte
    One solution would be to fire up your own APU and set up industrial shop fans aimed at your neighbors' APU's to direct the exhaust away from your truck.
