Axle weights
Discussion in 'Questions From New Drivers' started by SneekySnake, Nov 30, 2017.
  1. SneekySnake
    SneekySnake Bobtail Member
    My weights are steer 11940...drivers 34000...trlr 32800 and my fuel gauge is on 1/4 tank. My question is Can I slide 5th wheel forward so I can put fuel on n be legal. Need 140 gallons if possible. Thanks for any reasonable help.
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Trailer tandems all the way forward? Are you going through Maryland with this load?
  4. Moosetek13
    Moosetek13 Road Train Member
    14,656
    18,402
    Nov 1, 2010
    Burnsville, MN
    You will need to fuel more than once, because you won't get 140 gallons in there if your tandems are already all the way forward.
    You might manage 500 pounds by moving the 5th forward one hole. But that would put you to 12,440 on the steers.
    Add more fuel than you have now, and it will be even higher.
  5. TommyTrucker88
    TommyTrucker88 Light Load Member
    165
    135
    Nov 16, 2016
    POCONOS, PA
    You can try slide the trlr tires closer to the drives eeze some of that weigh off of the drives so you can add some more fuel.
    If I'm ever in a tight place I adjust my fuel stops.
    Nothing else you will be able to do.
    Pump only as much as you can to operate legally. And if that means making more then one or two stops for fuel that's what will have to be done.
    Keep in mind if your truck is equipped with a apu you have a 400-500 lb exemption to weight depending on state.
    So you might not have to do anything and still be able fuel and drive.
  6. gokiddogo
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Thread 2:
    Omg I am over 12000 on my steer axle! What now?!
    dunchues, Kyle G., TripleSix and 4 others Thank this.
  7. Moosetek13
    14,656
    18,402
    Nov 1, 2010
    Burnsville, MN
    Being over a bit on the steers isn't usually a problem unless it is way over.
    I've been at 12,400 many times on the steers in one truck, and never had a problem.
    But if the tandems are all the way forward with that kind of weight in front, there is little room to work with.
    Best to run it down near empty and put 50 gallons in for that trip.
  8. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Looks like your 5th wheel is where it needs to be. I would not mess with that now or in the future. Any fuel weigh you add will probably be distributed about 50/50 between the steer and drive. Your primary issue is needing to get the trailer to take more weight. Only way you can do this is move trailer tandems forward a hole, preferably 2 if possible, then you could probably top off
  9. Bean Jr.
    Bean Jr. Road Train Member
    5,500
    9,782
    Mar 30, 2014
    He was being sarcastic. The maximum allowed on a steer axle is not 12,000 lbs. It is the minimum of 20,000 lbs, single axle weight or axle rating or tire rating. Most, but not all 11r22.5 are rated ate 6,275, which is why you weren't harassed at 12,400 lbs. You were legal at least 2 out of 3, and I've never heard of them coming out and checking the axle rating.
    tinytim, ZVar and gokiddogo Thank this.
  10. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    Your 5th wheel needs to stay right where it is. Forget the steer weight for now.
    If you have I think two holes maybe to slide the trailer tandems forward to gather weight off your drives, there should maybe be a thousand pounds of room gained for fuel.
    Consider the following. 1000 pounds in fuel at 8 pound per gallon = 125
    Weigh that #### thing after sliding trailer forward to confirm you have that thousand pounds on the drives to fuel on. Weigh again after fueling.
    You did not indicate exactly where you are right now and where you are going, there is a process which you can take on your full fuel PROVIDED you BURN THAT down to below a certain level BEFORE you hit a KNOWN scale that's open. This is a sort of a very advanced trip planning work around which is used very very sparingly.
  11. kemosabi49
    10,599
    45,358
    Jan 13, 2013
    SW Arkansas
    Another thing to consider is where are you and where are you going. When/where on this run will you be crossing scales. Some good advice here but you need to give more info.
