Axles on fuel trucks
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Transit_lifer, Mar 21, 2020.
  1. Transit_lifer
    Transit_lifer Light Load Member
    143
    86
    Feb 23, 2020
    Hemet, CA
    What are the huge axle ends on the fuel trucks? They look to be about 8 to 10 inches in diameter.
  3. Cali kid
    Cali kid Road Train Member
    1,530
    1,840
    Feb 15, 2011
    IE, CA
    Maybe greased hubs?? We had those on truck and trailer setups when I ran fuel instead of oiled hubs. They were way better then oiled hubs.
  4. Transit_lifer
    143
    86
    Feb 23, 2020
    Hemet, CA
    This things are huge. Their way bigger than regular grease axle hubs with the plugs. Ill try and find a pic. Ive seen them on Superior tank lines trucks out here in So Cal.
  5. Transit_lifer
    143
    86
    Feb 23, 2020
    Hemet, CA
    volvo.png Look closely at the drive axles on this Volvo and youll see what I mean.....this is the closest pic I could find.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,104
    Mar 5, 2016
    White County, Arkansas
    Not enough picture to see.
    I don't see the need for huge (Relatively speaking) hubs holding enough grease or oil to stay cold or something else entirely. If I can discover why we have them...
  7. Cali kid
    1,530
    1,840
    Feb 15, 2011
    IE, CA
    Oh you must be talking about the tire pressure monitoring and inflation system. I believe they call it the HALO system, it has a big plastic housing that sits on the end of the axles.
    not4hire Thanks this.
  8. Cali kid
    1,530
    1,840
    Feb 15, 2011
    IE, CA
  9. not4hire
    not4hire Road Train Member
    7,142
    26,950
    May 16, 2012
    Calgary
    Yeah, that was what I was going to post as well.
  10. Transit_lifer
    143
    86
    Feb 23, 2020
    Hemet, CA
    that's it!
  11. not4hire
    7,142
    26,950
    May 16, 2012
    Calgary
    As mentioned, it's a self-contained tire inflation system. It is its own pump, there are no external connections for air like the systems you see that have a hose from over the fender connected to a hub device.
