Beeping sound when starting/running International Terrastar w/Maxforce
Discussion in 'Questions From New Drivers' started by cajundrag, Feb 15, 2018.
  1. LilBudyWizer
    LilBudyWizer Light Load Member
    185
    Thanks Received:
    169
    Is the temperature flashing?
  2. LilBudyWizer
    185
    Thanks Received:
    169
    Signing in posted both
  3. s0231198
    s0231198 Light Load Member
    Aug 23, 2008
    143
    Thanks Received:
    245
    If it's only for a few seconds, watch your oil pressure gauge, if it quits beeping as the gauge starts to go up, that's probably why it's beeping, and won't have a warning light on on the dash.
  4. Moose1958
    Moose1958 Road Train Member
    Dec 17, 2010
    15,169
    Thanks Received:
    33,411
    Williesburg, Virignia
    Having drove some Internationals I suspect you might be hearing the engine crank warning. This happens on most reefers too. This beep beep beep sound can drive a person mad when you are using the old self cranking systems for temp and battery control while asleep. Some mechanics can disable this warning. Now if it is something else it should show up with the gauges. As has also been brought up I think the FMCSA requires audible warning systems for low air pressure. Watch your gauges when you crank up. (something you should be doing already)
  5. d281833
    d281833 Heavy Load Member
    May 15, 2012
    881
    Thanks Received:
    919
    You picked up a Roadrunner in Phoenix?
  6. cajundrag
    cajundrag Bobtail Member
    Feb 15, 2018
    7
    Thanks Received:
    Now it may be a surprise to some of you but I am not a commercial driver. :) This truck is the chassis for our motorhome. Blinker fluid is full :) Now the washer fluid is currently empty, gotta go get some new fluid, but I wouldn't think the washer fluid being empty would make it beep. Checked the air in the tires all at between 88-90lbs on a warm La. day..
  7. aussiejosh
    aussiejosh Road Train Member
    Aug 28, 2009
    4,709
    Thanks Received:
    5,409
    Airlie Beach QLd
    Could be the low air warning does it stop once your air pressure builds up?
  8. Wicked Wizard
    Wicked Wizard Heavy Load Member
    Jul 15, 2008
    985
    Thanks Received:
    857
    Northeast PA
    Could it be a test beep? Making sure it works. Sort of like when you start your truck and all the lights go on? It's a test.
  9. Wicked Wizard
    Jul 15, 2008
    985
    Thanks Received:
    857
    Northeast PA
    You mean when the horn keeps beeping? That's when you open the door before all the air levels out after you pull the red and yellow. It irritates the heck out of me.
    bigkev1115 Thanks this.
  10. Bakerman
    Bakerman Road Train Member
    Jan 27, 2013
    4,663
    Thanks Received:
    8,812
    Phoenix, AZ
    Is the vehicle in reverse?
    Justrucking2 Thanks this.
