Benefit of double clutching
Discussion in 'Questions From New Drivers' started by Heysunshine, Apr 7, 2014.
Page 1 of 4
Double clutching is for non-synchromesh transmissions.
Simply put, big truck transmissions are not synchronized. Double clutching matches the main shaft speed of the transmission to the engine speed/rpm. <br><br>On upshifts, clutch in, shifter to neutral, clutch out, clutch in shifter to next gear, clutch out. Timing is every thing, match rpm to road speed. Sounds funny, but think of the adams family theme song to get the perfect timing. The whole shift should take place during the duh-duh part of the song lol.<br><br>Downshifting, clutch, shifter to neutral, throttle up/ clutch, next gear. Much easier, just have to match the road speed to the proper gear, and learn to be quick.<br><br>Any help?
Heysunshine and Semi-Truculent Hamish Thank this. -
Sunshine it's supposedly is supposed to make taking it in and out of gear easier. It "saves" the transmission by not chewing up gears. But I've found its harder on the trucks by creating lash in the drive line. Clutching out may help but clutching in doesn't do much to be honest. Plus you will burn up a clutch pretty quick if your not fairly good at it. If your new to gear grabbing I say go ahead and by all means do it. But if your getting a little time under your belt then ease yourself into floating the gears. May be rough at first but worth it in the long run. Ps don't tell anyone about this. I'm a trainer for the same company. Lol
Redriderex and Heysunshine Thank this. -
It makes your left leg much larger than your right so you walk in a circle.
Heysunshine, bigmikectn, Mr Ed and 11 others Thank this. -
Clutches ... We don't need no stinking clutches... Double clutching is how you are to learn shifting a non synch transmission. Once mastered you may be able to start floating. As long as it's done with out grinding ! Grinding is not good no matter the shifting method ! Have had trainees ask if my truck was a auto ? Made me laugh, "you see me shifting" !
KF7WTV Thanks this. -
That's pretty much why I was asking. When I learned to drive it was floating. When I got my CDL I had to learn to double clutch. And I'm pretty terrible at it. Just had an evaluation with the company I work for and got chewed for not double clutching. My floats are smooth, no raking or grinding. I was just wondering what benefit there was to using the clutch. Aside from hard breaking and the occasional double down, I don't use it.
If there was a huge positive to double clutching I was considering trying to teach myself again, haha! -
double clutched with a set of sticks but quite when i went on a single stick truck. to me its just something to do if you are bored. with the ease of driving these new trucks you dont really need to do it. i know a lot of young drivers are going to rear back and say they do it all the time but i was driving before some of them were even born, so by now should know a little bit about shifting and clutching a truck and like sdanial said grinding is bad. be safe out there
I was more or less curious as to why they teach double clutching in schools these days, since I didn't learn that way. And why I was scolded by my company months later. If floating was harder on my transmission I was debating the double clutch system. I may be a company driver, but I know that when my truck is in the shop I'm not making money. The less preventable wear on my truck the better.
You get into any kind of serious construction sitework driving, you'll learn the benefit of it quick. You'll hit a good number of access 'roads' or running over bare earth where the only way to not get stuck is not to stop. Hitting soft spots where you have to suddenly drop several gears quickly, you won't accomplish by floating - least of all, while you've got the power divider and differential locks engaged.
48Packard, windsmith, Heysunshine and 2 others Thank this.
Page 1 of 4
