Best fuel mileage, Cascadia, Pete, or LT
Discussion in 'Prime' started by ghostzapper, Oct 22, 2018.
The brand of the truck won't matter much. It's what's under the hood and between the tires that matters.
Between the three aerodynamic trucks there is virtually no difference... +/- 2%
... the biggest difference is the proper specifications of the Driveline. That can change MPG by 15% + with good or bad specs.
Motor specs, transmission, gear ratio and tires -
If you're just judging from an aerodynamic look, its a toss up. It's so many things that factor in fuel mileage. Good filters, fuel injectors, regular oil changes, idling, weight of the load, speed going down the highway, tire pressure, dirt accumulated on the truck and motor, even the trailers with those trailer skirts and wings in the back, affect fuel mileage
