Best truck for LTLs
Discussion in 'Expediter and Hot Shot Trucking Forum' started by tedlish, Mar 15, 2009.
  1. tedlish
    tedlish Bobtail Member
    6
    Apple Valley, CA
    Hi all,
    I'm a retired school teacher looking for something fun and profitable to do.
    I'm considering buying a truck for delivering LTLs. I want an automatic transmission, air-conditioning hydraulic brakes, and no trailer. What would be a wise choice of a truck (something in demand)? Also, I'm old (68) so I don't relish the idea of loading and unloading. I only want to drive within 500-600 miles from home, so I can be home when I want. Any suggestions?
    Thanks,
    Ted Lish
  3. RickG
    RickG Road Train Member
    12,814
    6,123
    Jul 22, 2008
    Owensboro , KY
    You'll have a hard time getting all you want and having it profitable . It would be hard to get a straight truck without airbrakes although they are out there . If you find one though it won't meet the requirements of any expedite carrier . You might as well get a cargo van . Getting a carrier to sign you on to run the way you want would be difficult . Unless expediters live in Ohio or Michigan they run all over the country and stay out 3 or 4 weeks at a time . You could get your own authority and find your own loads but it would be difficult to make a profit as low as rates are .
    If you want to stay under the 26,000 lb. CDL requirement the largest truck you can get is a class 5 (Dodge/Chevy 5500 , Ford F-550 . )
    heyns57 Thanks this.
  4. BoostedTeg
    BoostedTeg Road Train Member
    1,524
    2,193
    Jun 2, 2008
    Boise ID
    ^^^ Either that or get a 24 foot moving truck.
  5. RickG
    12,814
    6,123
    Jul 22, 2008
    Owensboro , KY
    That wouldn't allow loading and unloading at docks . A lift gate and pallet jack would be a good idea also .
  6. tedlish
    6
    Apple Valley, CA
    Thanks! I am looking at an 18' chevy dry van 5500 with an Izuzu diesel engine.
    A local dealer has it. It is a new 2007 model. They want $30,000. I plan to get my own loads through someone like Direct Freight on-line.
    Ted
  7. tedlish
    6
    Apple Valley, CA
    Yes, I see that I'll probably have to buy a pallet jack and have a lift gate installed.
    Best,
    Ted
  8. BoostedTeg
    1,524
    2,193
    Jun 2, 2008
    Boise ID
    good luck to you keep us updated on how things go for you.
  9. xiggi
    xiggi Bobtail Member
    13
    5
    Feb 20, 2009
    New Castle, IN
    If I was you before buying a truck I would put some calls in to local expedite companies. Ask them what would work for them, having a truck no one wants will only cost dollars. You might want to consider as sprinter. The mpg's is great and you can put a nice bunk in one and still haul two skids.
  10. RickG
    12,814
    6,123
    Jul 22, 2008
    Owensboro , KY
    If it's a 2007 Chevy it has a Duramax engine built by DMAX . Once a joint venture by GM and Isuzu , GM bought out Isuzu's share in 2003 . The engine is built in Moraine , Ohio . The Duramax , Allison Automatic is a good combination . I know several hotshotters running them . It's a good truck . You should try to build up a customer base you can bill directly to avoid paying brokerage fees on all loads .
  11. tedlish
    6
    Apple Valley, CA
    It really is an Izusu made in Japan for Chevrolet. It's a W5500 series. The engine is a 4HK1-TC Turbo/Intercooled Diesel 5.2L. I bought it today. It's a tilt-cab and feels like you're driving a bus. I agree I'll have to develop a customer base. I have no intention of contracting with an expiditer. I consider myself an owner/operator and will pick up loads when and where I can. It has an 18' dry box, is dock height and can carry a little over 11,000 lbs.
  • Draft saved Draft deleted
