Better Refeer unit Vs. Better trailer?
Discussion in 'Ask An Owner Operator' started by SemiMan, Mar 30, 2015.
  1. SemiMan
    SemiMan Light Load Member
    May 21, 2013
    60
    Thanks Received:
    What is more important, a better model refeer unit that cools very well, or a newer better trailer to have a better seal/insulation?
    I currently have a 210 SB TK reefer unit with a rebuld eng on a 2006 Utility
    trailer. We have been having issues with it dropping down to -10 temp and holding it. It takes us 8 hours to drop down to -2 in 90's degree weather. The trailer has no holes and doesn't have any cracks when examined being inside with closed doors. We have also checked the refeer unit at TK and they told us it is working well with no issues, so we are not sure who is at fault here.
    Whats more important a Refeer unit or a good trailer?
  2. wichris
    wichris Road Train Member
    Jan 17, 2011
    4,276
    Thanks Received:
    8,603
    If the insulation is soaked no unit will cool it easy.
  3. SemiMan
    May 21, 2013
    60
    Thanks Received:
    How to check for that?
  4. wichris
    Jan 17, 2011
    4,276
    Thanks Received:
    8,603
    Fast way, thermal camera. Slow way, -10 load and see how much it "sweat" on the outside.
  5. Army91W
    Army91W Heavy Load Member
    Nov 3, 2006
    751
    Thanks Received:
    733
    San Antonio, TX
    Not harping on you but had a hard time reading your post with the font you chose.
    I currently have a 210 SB TK reefer unit with a rebuld eng on a 2006 Utility trailer. We have been having issues with it dropping down to -10 temp and holding it. It takes us 8 hours to drop down to -2 in 90's degree weather. The trailer has no holes and doesn't have any cracks when examined
  6. SemiMan
    May 21, 2013
    60
    Thanks Received:
    Fixed the font
  7. RedForeman
    RedForeman Momentum Conservationist
    Jan 30, 2011
    4,875
    Thanks Received:
    22,138
    Thermal camera is nice, but there's an easier way to find leaks than condensation. Get the unit cooling and go over it with an IR temp gun. Start with the obvious seals on the door and where the unit mounts, then work your way around the van. Don't forget the underside and the roof.
    Both.
    A 2006 trailer shouldn't be a problem, unless there's some damage somewhere or the chute is torn up. The SB-210 is a mid-range unit that's ok for frozen product, but not so great at it when the outside temps are higher. What you're describing sounds a little worse than normal for an empty trailer in 90º weather. You should be able to start the unit on an empty trailer and pull down to at least +10ºF in under an hour. If not, there's probably something wrong with your equipment, although the unit itself may be running ok and not throwing codes or have unusual readings.
    Crank it up and take a walk inside and look up to make sure the chute is in good condition and attached properly. Feel for where the air flow is. After a tour of the inside, shut the doors while checking the seals and a temp gun to find leaks. Get a ladder if you have to in order to check the tops. If there's no ladder around, I have used pallets and load locks to fashion a ladder inside to examine the tops of the doors one at a time. Yeah, you don't want to do that with both doors open without a helper to call the ambulance for you.
    On the unit, most likely to cause poor cooling would be trash in the evaporator (remove panel inside the trailer to get at it and clean out) or truck exhaust soot clogging the condenser (top of unit outside, use a pressure washer). Next thing would be to verify defrost cycle is functional. After running an hour and hitting the defrost button you should get a couple gallons of water out the drain pipes. If you got into the evap housing to clean out, don't forget those defrost drain pipes too while you're in there. If that water isn't draining out through the drain pipes, it's probably leaking inside the trailer and covering part of the evaporator, which could cause the poor cooling.
    Hope that helps.
    2Girls_1Truck Thanks this.
  8. SemiMan
    May 21, 2013
    60
    Thanks Received:
    We do not have a chute, could that be one of our issues? Is a chute very crucial in cooling down the trailer?
  9. RedForeman
    Jan 30, 2011
    4,875
    Thanks Received:
    22,138
    I think it would be more important with product loaded, to force the cold air to circulate all the way to the back of the load. With a load, not only are you getting the benefit of less air volume to cool, but the better circulation would bring that air across more of the (presumably) already cold cargo.
    Without a load no chute ought to come down to temp a little faster, albeit with the back of the van not actually reaching the inlet temp displayed on the unit. Can't say for sure because I've never run one without a chute. Maybe someone that has will chime in.
    Edit to add: After thinking on it, I have hauled one trailer without a chute with a frozen load. It was a 48' flat floor with a rollup door I was moving for a customer. I don't recall it really taking noticeably longer or shorter time to cool down. So there it is: one in a row. Maybe someone whose run more than one can add something.
