Boost leak when cold outside and climbing hills.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Apr 19, 2021.
  1. mitmaks
    mitmaks Road Train Member
    2,450
    1,952
    May 16, 2014
    I have boost leak somewhere. Especially when it's cold outside ill start climbing a hill when I hear loud pfffttt and it looses power for split second. They sell those adapters that bolt onto turbo inlet. Do I need size 5" or bigger? Any better ideas to check for boost leak?
  3. MTN Boomer
    MTN Boomer Road Train Member
    1,157
    1,960
    Feb 4, 2019
    Tighten the clamps on the boots on the air to air.
    mitmaks Thanks this.
  4. lester
    2,817
    7,478
    Jan 2, 2012
    NW, Iowa
    Your symptoms don't sounds like a boost leak to me. Wouldn't just loose power randomly for a split second
    God prefers Diesels Thanks this.
  5. mitmaks
    2,450
    1,952
    May 16, 2014
    Already tried that. I think I have crack/pinhole on cac somewhere
  6. MTN Boomer
    1,157
    1,960
    Feb 4, 2019
    Yes , would t be that simple would it?
  7. mitmaks
    2,450
    1,952
    May 16, 2014
    What size pipe intake is it? Looks like4.5 inches? Or is it 5"
  8. God prefers Diesels
    4,198
    22,246
    Jun 26, 2020
    South Texas
    It should be a constant leak then. It really sounds like the EGR valve is getting forced open, and that noise you're hearing is turbo bark from air rushing back into the turbo after lack of drive pressure under load. Which engine do you have, and what year?
  9. mitmaks
    2,450
    1,952
    May 16, 2014
    Its 2013 isx15.
  10. God prefers Diesels
    4,198
    22,246
    Jun 26, 2020
    South Texas
    Might also check out Rawze.com too, if you haven't.
  11. Goodysnap
    Goodysnap Road Train Member
    3,502
    8,384
    Jul 12, 2017
    Smoke.
    Once you buy a smoke machine you will throw the pressure test adapters in the garbage. Just hook it up and sit back and watch.
    Plus it finds the smallest of leaks.
    Theres tons on the market. Most commonly used in automotive evap system testing.
