Bore brush recommendations for Cat and Cummins blocks
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Feb 7, 2026.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,415
    1,738
    Dec 4, 2019
    In the process of cleaning up a BC block and was wondering about bore brushes, for cleaning the lowers. Are they worth buying or necessary?
  3. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    When you say lowers? What specifically are you cleaning.
    Harbor freight has lots of bore brushes in steel, brass and nylon. Decent quality and inexpensive. They also have a short set that has the drill chuck built on them.
  4. Big Road Skateboard
    7,068
    40,044
    May 2, 2021
    If you're talking where the liner o rings seal, I always just used scotch brite.
    I don't like using brushes in areas where something like a broken wire or such can get around the crank. Just personal preference.
  5. Goodysnap
    3,771
    9,195
    Jul 12, 2017
    I use a stainless twisted wire wheel on the bores.
    Like this one-3" Twisted Wire Wheel (Heavy Duty - .014 Wire)Default Title
    They barely shed wires and are heavy enough to clean out and don’t get hung up in places. Then follow up with a red scotch pad as suggested.
    Just to add…… Keep any rotating tool under its rated rpm. Any Chinese wire wheel will come apart at the end of a 20000 R die grinder.
    mile marker 27 and Oxbow Thank this.
  6. mile marker 27
    1,415
    1,738
    Dec 4, 2019
    The last couple I’ve built I just used very light emory cloth but I’m always hearing suggestions so, I thought I’d ask.
