brake air leak (1993 International 9400-Series 60)
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by RWCDL, Jul 26, 2021.
  1. RWCDL
    RWCDL Bobtail Member
    When I step on my brake pedal, I get a rapid air leak the harder I press the pedal. I located the air hiss, and it’s coming from outside under the hood coming out of the firewall. It is a small plastic tube that goes no where. I thought either it was a broken tube, but I don’t see where it could go to. Or I thought it could be some sort of breather tube. But that don’t make sense to me either. I know I shouldn’t be losing air from it when I’m pressing the brake. If I can figure out how to upload a picture of it, maybe someone can tell me why it’s leaking brake air. I assume it would not be wise to plug it. Even though it does not leak anymore if I plug it. But I don’t know if that will affect any other part of my air system or braking. Any ideas?
  3. MLC Adventures
    MLC Adventures Medium Load Member
    452
    1,041
    May 2, 2021
    Leaks only when brakes are released? Most likely a brake chamber
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    3,454
    4,800
    Aug 26, 2014
    Valves, air wiper motors and such are often vented to outside the cab.
    You should be able to flip a few dash panels out and trace it down. Does it go to the hand valve? Could be a bad tractor protection valve back feeding through the hand valve.
    spsauerland Thanks this.
  • Draft saved Draft deleted
