Brake line dryer for the trailer.
Discussion in 'Experienced Truckers' Advice' started by snowwy, Jan 13, 2025.
  1. snowwy
    snowwy Road Train Member
    20,587
    13,307
    Jul 6, 2009
    Anyone aware of a glad hand setup we can hook up to the trailer to pour that dryer directly down to the trailer lines. Rather then using the truck air line connection to blow it through to the trailer???
    I want to hook something up to the trailer and pour it down that way.
    Big Road Skateboard Thanks this.
  3. Goodysnap
    Goodysnap Road Train Member
    3,744
    9,105
    Jul 12, 2017
    We use to have a homemade one that was made out of a 1 foot long piece of 2 inch pipe. Pipe caps on both ends. Drill and tap the caps, put a glad hand on the top and on the bottom put a shutoff valve with shop air fitting.
    Worked pretty good. Close the valve, remove the top cap with gladhand and poor in. Hook up and charge the trailer. If you use a universal gladhand you can hook up to both sides.
    86scotty and Big Road Skateboard Thank this.
  4. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    948
    1,836
    Dec 15, 2021
