trying to figure out a pain in the ### issue with my breather lights , a day or so ago the passenger side air breather lights stopped working (peterbilt379,02) the driver side is working but some reason the passenger is not anymore, can't seem to find an inline fuse anywhere behind the dash or anything in the wiring coming from outside of the cab behind the breather .. any help is greatly appreciated, it seems so simple but I may be overthinking it new to the forum thanks everyone
Breather lights
Discussion in 'Canadian Truckers Forum' started by JncPetercar, Nov 11, 2016.
If that's not the issue, are you getting juice to the lights?
Do you have a voltmeter? -
What's the outcome? Did you figure the problem out?
Left and right are most likely wired to the same circuit, so you at least know you have power to the switch. Good chance your issue is a rotten ground or a broken power wire between the junction (between left and right wires) and the lights themselves.
dustinbrock and JncPetercar Thank this. -
Id ask @NorthernMechanic first. I myself am a wiring rookie, Northern probably has way more experience.
JncPetercar Thanks this. -
Blackshack46 Thanks this.
Check and see if you have power on the left breather light harness. Volt meter or test light.
