Brief check engine light on 2007 Columbia?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mcast3092, Jan 20, 2022.
  1. Mcast3092
    Mcast3092 Light Load Member
    137
    106
    Jul 31, 2018
    I’m having trouble getting an appointment with a mechanic so I’m hoping someone here can help me out. I have a 2007 freightliner Columbia with a 14 L Series 60 with a full delete. Once or twice a week when going up a hill at approximately 15 RPM I get a check engine light that lasts about 30 seconds then shuts off.Is there anyway to check what this is, and do you guys have any ideas on how to troubleshoot. thanks in advance.
    biopure22 Thanks this.
  3. biopure22
    biopure22 Light Load Member
    87
    51
    Aug 22, 2021
    What part of the country you in?
  4. truckdriver31
    6,986
    8,340
    Sep 18, 2013
    check the coolant level. those trucks have to run high coolant level above the bottle sensor. the water pump draws so much in a pull. it can cause a low coolant light and shut down. run coolant level about 1-2 inches above the line. hope this helps
    little cat 500, Chieftains and MOBee Thank this.
  5. Mcast3092
    137
    106
    Jul 31, 2018
    PA
    truckdriver31 Thanks this.
  6. biopure22
    87
    51
    Aug 22, 2021
    #### I’m if you wer in atl I could hook up Jpro software up to it for free.I’m in my last semester of tech school and we have a software we are allowed to use called Jpro
  7. little cat 500
    1,950
    1,004
    Jan 17, 2010
    Abbottstown PA
  8. nikmirbre
    nikmirbre Road Train Member
    5,050
    8,692
    Jul 27, 2011
    High Point NC
    I had same truck/same engine and same set up. I also had the same issue. Try changing your turbo boost sensor. There is another sensor, I think its a manifold sensor or something, change that one also. It fixed my issue a few years back. Light would only come on in a hard pull such as going up a hill. Didnt come on all the time but, it did it every now and then.
    Mcast3092 Thanks this.
  9. Rideandrepair
    16,522
    53,935
    Aug 8, 2015
    Doesn’t your Truck have a self diagnosis (overide) button? Key on, push and hold button. Count the yellow (stored) flashes or red ( active) flashes.
    nikmirbre Thanks this.
  10. Rideandrepair
    16,522
    53,935
    Aug 8, 2015
    I’ve had a similar problem. It was caused by the fan coming on, and blowing the coolant sensor plug. Caused it to wiggle and eventually an intermittent break in the wire. New pigtail, and secured better fixed it. Best to get a code, if there’s one logged. Can also get a code while it’s active. Beats guessing which sensor or wire.
  11. nikmirbre
    5,050
    8,692
    Jul 27, 2011
    High Point NC
    If his truck was anything like mine(mine was deleted and had same exact symptoms) it of course only flashed "25". I would remove the turbo boost sensor and clean the bottom of it and it would work also.
    Rideandrepair Thanks this.
