Bullet Connectors
Discussion in 'Kenworth Forum' started by droy, Jun 23, 2012.
  1. droy
    droy Heavy Load Member
    828
    159
    Jun 11, 2008
    Iowa, LA
    Wondering if those electrical connectors (bullet type) that KW uses so much, can be bought over the counter? They are similar to the type you can get at any parts house, but larger. Part # ? If not available thru KW, does anyone know where they could be found, or who makes them for KW?
    Also looking for the send unit part #s for the fuel and air filter restriction gauges. My 2007 T800 did not come with them, so posting my "last six" will not help. I have already added the gauges, now need to mount and hook up the send units.
    Thanks.
  3. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    I used to get my bullet connectors @ KW but they were a little cheaper at on the internet, 086997 ('05 T-600)is my last six will get you a fuel restriction gauge sender for a Cat, the air filter restriction on mine is a vacuum hose hooked to the passenger side of my underhood housing.
    droy Thanks this.
  4. rollin coal
    rollin coal Road Train Member
    13,270
    26,733
    Mar 29, 2008
    TN
    If '05 is too new, I'm thinking they have a newer style gauge, you can use my VIN 397114 for a fuel restriction gauge. My truck has the older style gauges. Don't have an air restriction gauge - only a filter minder on the filter housing.
    droy Thanks this.
  5. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,116
    May 19, 2011
    An 05 could have the same gauges as your 03. It was mid year in 05 when they went to the new style gauges. My 05 has the same gauges as your 03, the op has an 07, so he would have the new style gauges. I am not sure if they would share the same sending units or not.
    droy Thanks this.
  6. rollin coal
    13,270
    26,733
    Mar 29, 2008
    TN
    Doh!! missed that important detail - OP having an '07 - don't know wth I was thinking.. wasn't sure when the newer style gauges came out..
  7. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    '00 KW W900 with fuel restriction gauge. Im sure to old for style of gauge your looking for but here it is...
    VIN 849801
