good fast way to tell if the engine has a burned piston, new head, old injectors reuunin good when replaced head
burned piston 60 series 14 l
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by o1reb, Jul 28, 2019.
Blowby tube chuffing like a locomotive is a real good indicator.
AModelCat, Intothesunset and spsauerland Thank this. -
How long did it run after the head was put on before this problem?
Why was the head replaced and what else was done? -
Is your quarter fender full of oil??
swaan Thanks this. -
We had a factory new rebuild from Detroit in one of my companies 3 year old Harison gliders split a piston and drop a valve out of nowhere with 250,000 on it.
Meticulously maintained, running right not pulling hard.
Very experienced mechanic who pulled it apart couldn't determine if the valve or the cracked piston was the first failureIntothesunset Thanks this.
