I'm looking for some input here. I have the stock turbo, its a non waste gated model that only puts out about 20 pounds of boost, with a 430 HP setting mated to an Allison automatic. It's a DDEC 4 model.
I keep reading that the waste gate kills efficiency upend, but from what I'm reading, the 172743 with waste gate gets better fuel economy and performance. I'm not concerned about fuel economy, I want power when I mash the pedal. I also plan on getting a tune when I'm done. The stock turbo just has too much lag, and takes too long to spool up.
Here's a website for the 172743:
https://www.citydiesel.net/hot-rod-...-p-216.html?osCsid=fdkhn665k4c7rjbma3cf49pf52
Summit has the 171702 here:
https://www.summitracing.com/int/parts/bww-171702/overview/
Thoughts? Each of these I'm reading differently, with the non-waste gate generating 40 PSI of boost, and the 171702 generating up to 70 PSI of boost. I don't even know what a safe boost level is on a Series 60 GK engine. Thanks.
BW 171702 VS BW 172743 waste gated in 12.7 Series 60 Detroit
Discussion in 'Trucks [ Eighteen Wheelers ]' started by allisonisatranny, Apr 2, 2017.
I've never used the 172743 so I don't know anything about it. I can tell you this though: If the waste gate opens at 40psi, that means that engine will never be able to produce more than about 650hp. Those 12.7s produce somewhere around 16hp per pound of boost so if you want power, you want boost. The 171702 is a great turbo upgrade for the 12.7. You'll get a little more lag but more top end boost. If you don't want the added lag, upgrade to a high flow manifold/mufflers at the same time. Keep in mind that a turbo rated for up to 70psi isn't going to get you 70psi without a lot of other upgrades. As far as what a Series 60 can take for boost, it all depends on who built it and how the overhead is set. If the liners are on the low end of spec, goodbye head gasket. Much over 50psi and the valve on a lot of them will start to float
dustinbrock, JPenn, MoneyCat and 1 other person Thank this.
Lots of folks post just to post. BUT this fellow knows what he is talking about!! I run the 60 and your answer is spot on correct.
Ruthless, allisonisatranny, MoneyCat and 1 other person Thank this. -
171701 might work better on 430 hp
allisonisatranny Thanks this. -
Please explain the differences, I don't know anything about turbo's. Having the Allison 6 speed automatic, I wont weigh more than 45k, I don't care about fuel economy too much. I just want the performance. The most horsepower I plan to do with this engine, is probably 500-550 max, since it's not made to handle high horse power. The turbo lag down low and off the line is a real disappointment, which is why I'm looking at the wastegated turbo.
I see another part number someone posted up, I don't want to deal with the same issue of turbo lag. That K31 turbo, I'm hoping it puts out more boost as well over my stock non-waste gate. -
If you want to be peppy off the lime the ecm has to be adjusted to give fuel b4 7 psi boost. Turbo might help a little but not the real issue.
leon can make it run
Are you sure that you have a stock turbo on there now and that it's a DDEC 4? DDEC 4s have waste gates. The fact that your 430 is only making 20psi of boost is a little concerning too. It should be up around 26. Are you sure the gauge is working correctly and that you don't have any leaks? I would check into that before changing your turbo. From what I've been able to find on the 172743, it's similar in size to a stock turbo but it has a more aggressive inducer so it spools a little faster. The 171701 mentioned is like that except it doesn't have the waste gate. In my opinion, the 171702 with the manifold, mufflers and a good quality tune (you usually get what you pay for) is the way to go
