Bypass apu coolant
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bibin, Jun 5, 2018.
There should be shut offs under the hood where it connects into the system.
I can not find shut off,need some different approach..Can I put two coolant hoses together in order to bypass apu?
You can do it that way, or you can find a way to pinch off the lines. Some setups have cutoff or bypass valves in the back towards the APU, as well.
Did you bust a radiator on yours or something? -
Yes,it looks like radiator . I'm going to bypass for now.
Thermo King or Carrier?
I wanna know if I can just run the coolant hoses together, and if the truck radiator will keep my carrier apu cool enough?
