C-15 mbn lower boost than normal
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Robertstrucking2285, Jun 23, 2022.
  1. Robertstrucking2285
    Robertstrucking2285 Bobtail Member
    4
    I have a 379 with the c-15 mbn a couple weeks ago it started missing bad while accelerating, replaced wiring harness under valve covers and went through the harness from ecm to the rocker box. Replaced the ecm and #6 injector. Runs a lot better now but something still isn’t right. Loaded and full throttle I can only get about 22 pounds of boost through any of gears, truck had more power before this started. I hook up the truck to computer and shows no codes but if I do the diagnostic using the cruise control it shows boost pressure sensor fault atmospheric pressure sensor fault and at one point it showed injector 3 or 4 fault. Any ideas on the next step I should try? I don’t have the money to just start buying parts and it not fix it. Thanks so much for any help.
  3. baha
    baha Road Train Member
    4,058
    2,713
    Jul 25, 2013
    ga
    You need to replace the pressure sensor it can make truck run bad when it gives wrong information like the truck is on top of rocky Mt out W. or at sea level when you are on top of Mt. to the ecm ?
  4. Robertstrucking2285
    4
    I run Louisiana Mississippi and Texas
  5. Magoo1968
    Magoo1968 Heavy Load Member
    886
    2,387
    Mar 18, 2021
    St Malo mb
    Odds are you had a non bridge program before and new ecm has a bridge program which many including myself find very lazy.. find some to flash a 6nz program into ecm and it should wake up.
    spsauerland Thanks this.
  6. lester
    lester Road Train Member
    2,211
    5,404
    Jan 2, 2012
    NW, Iowa
    I drove an MBN that wouldn't build boost past 22lbs as well. It's the crappy mbn tuning and electronic turbo actuator. Different tune and getting rid of the electronic actuator will do wonders.
    Magoo1968 and spsauerland Thank this.
  7. Robertstrucking2285
    4
  • Draft saved Draft deleted
