Hello everyone! First post on any forum ever so apologies in advance if I’m not posting in correct place or if this info is on here somewhere else and i missed it. I have a c13 Caterpillar serial #LEE 06XXX with 850,000 miles, 24,0000 hrs on it, was emissions deleted(dpf,cgi,iva’s turned off,22psi wastgate) at 400,000 miles. Having to replace cam shaft and lifters(suspect that fuel dilution in oil from bad injectors was cause. Doing in-frame already replaced injectors) and trying to find out if the stock camshaft part #2601814 is my only option or if an alternate part # would be a better fit for my current setup. Readily available alternatives that I’ve come across are 223-4468, 223-7468, and 230-0065
C13 LEE camshaft replacement options
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by C13m57, Jan 18, 2022.
