C13 oil temp gauge stock vs aftermarket
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by OFT2024, Nov 4, 2024.
  1. OFT2024
    OFT2024 Bobtail Member
    17
    Apr 23, 2024
    05 c13
    can you use a aftermarket (teltek) gauge? Or does the computer use the oil temp and or will throw a code if unplugged?
  3. IH9300SBA
    IH9300SBA Road Train Member
    2,364
    23,044
    Feb 26, 2021
    Don't believe CAT has an oil temp sensor, they calculate by coolant temp / engine load and a couple other factors. The gauge is likely reading a sensor in the oil pan sump and supplied by the OEM and has no effect on the engine.
    bjytech Thanks this.
  4. bjytech
    bjytech Light Load Member
    244
    221
    Nov 9, 2013
    No oil temp sensor on the engine side of a C13, so any oil temp sensor you have is by the truck manufacturer, so you can put whatever you want in for one.
