So I bought a truck and the ecm went bad almost right away. got a new ecm from cat set to 550 from 475. Thing runs like crap. I never got to pull a load with it at 475 so I don't have anything to compare it to with the previous hp rating. The truck falls flat and any bit of a hill. You got doubles and triples passing you. Pulls like its got 250hp. I checked fuel pressure 85psi at idle 115psi at 1500rpm. Runs about 40-45lbs of boost no leaks there. Kinda at a loss of why the thing wont run.
C15 Acert 475 to 550 running like crap
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by DEVINKLUG301, Feb 1, 2022.
No need to start another thread, we all see what you posted on the first one. Seems you didn’t like the answers your getting on the other thread so you started a new one. Be patient, others will chime in.
Last Call Thanks this. -
Have you done any injector tests , Any pressure in the rad ? Any fuel in the oil ?
How do you know it doesn’t have any boost leaks?
Also depends on the engine family . Did cat say 550 uprate was ok ?
Also just an FYI a 475 heavy haul program will still give you 1850 torque , use less fuel and mine will run all over a 550
