C15 BXS losing turbo boost
Discussion in 'Trucks [ Eighteen Wheelers ]' started by russtrucker, Jul 4, 2019.
  1. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    I'm driving 05 Peterbilt 379exhd that has CAT C15 bxs with a delete wastegate. On a usual basis turbos would boost all the way to 48 psi. Yesturday, I noticed the turbo isnt boosting than it supposed to and climbs up the hill slower, even with an empty trailer. It only boost up to 29 psi around 1200-1600 rpms. 1600 and higher, just spits 35 psi. Could this be a turbo or other air components such as intake, CAC, or exhaust manifold?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,723
    Jan 30, 2010
    keep stroking.
    What do you mean waste gate delete ? One of the turbos failed. Or you just have a boost leak. Turbo boot or cac or clamp.
    Oxbow, Cam Roberts and stillwurkin Thank this.
  4. tnevin225
    tnevin225 Road Train Member
    1,166
    1,600
    Jan 1, 2014
    More than likely one of your valve actuators is bad, it limits the turbo pressure as a safety feature to keep from doing damage. Those motors have a reputation for actuator problems, sometimes it's just the wiring going to it also.
    russtrucker Thanks this.
  5. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    As I gave few more days, turns out cylinder #6 exhaust manifold gasket is leaking.
