C15 noise in motor
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by anthonyar4, Nov 27, 2020.
  1. anthonyar4
    anthonyar4 Medium Load Member
    428
    91
    Jun 8, 2019
    So would that make the noise then?
    Trucking Jobs in 30 seconds
  3. anthonyar4
    428
    91
    Jun 8, 2019
    On that style?
  4. 062
    062 Road Train Member
    4,168
    8,040
    Oct 20, 2013
    I was just saying how I tighten the belts. Unless you’re very strong you will never be able to get the belts tight lifting by hand or even with a pry bar.
  5. bad-luck
    bad-luck Road Train Member
    1,482
    1,855
    Nov 16, 2013
    Baltimore, Maryland
    Check the belts, could be the a/c compressor bearing or the fan hub bearing
    anthonyar4 Thanks this.
  6. anthonyar4
    428
    91
    Jun 8, 2019
    My buddy said it could be my throw out bearing. Are there grease fittings on this.
  7. bad-luck
    1,482
    1,855
    Nov 16, 2013
    Baltimore, Maryland
    If it is the throw out bearing, push in the clutch to the floor and it will stop making noise. If it doesn't, it's not your problem
  8. anthonyar4
    428
    91
    Jun 8, 2019
    Thank you. I think it’s the AC compressor. As my ac does not work. Really appreciate it buddy.
  9. anthonyar4
    428
    91
    Jun 8, 2019
    Do they have grease fittings on here
  10. anthonyar4
    428
    91
    Jun 8, 2019
    I always got them DOT tight when I did it lol.
  11. bad-luck
    1,482
    1,855
    Nov 16, 2013
    Baltimore, Maryland
    Yes, but if it is your problem and its that bad, grease may quiet it down but it won't go away.
  • Draft saved Draft deleted
