C15 Part Stuck To Engine Oil Drain Plug
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Chris Firman, Feb 17, 2020.
  1. Chris Firman
    Chris Firman Bobtail Member
    6
    Oct 3, 2019
    Good morning everybody.
    I’m in the process of changing a water pump on a 2006 KW T800 with a C15 MXS. Since it was due for an oil change, I dropped the oil as well. There were 2 pieces of metal stuck to the magnetic drain plug. My previous experience is with farm equipment, and we never got to do much engine work at my last shop. Any help identifying these parts and figuring out what to do next would be greatly appreciated. Thanks in advance!
  2. pushbroom
    pushbroom Road Train Member
    1,413
    5,776
    Sep 1, 2012
    Looks like an adjusting screw for a rocker. Might have been from a previous failure.
    I would pull the valve covers and take a look.
  3. Chris Firman
    6
    Oct 3, 2019
    Sounds good! Thanks again for the help!
  4. Superhauler
    Superhauler TEACHER OF MEN
    9,824
    79,247
    Jan 30, 2010
    Your feeble mind
    That or if small enough adjustment screw for jake or vva.
    Shawn2130, AModelCat and pushbroom Thank this.
  5. Chris Firman
    6
    Oct 3, 2019
    It turned out to be one of the bleed orifices from the IVA housing. The housing is cracked. Thanks for all of the help!
  6. Chris Firman
    6
    Oct 3, 2019
    This is where it cracked.
    spsauerland and pushbroom Thank this.
  7. Goodysnap
    Goodysnap Road Train Member
    1,631
    3,146
    Jul 12, 2017
    I'd pull all of them and inspect for loose or broken rocker mount studs.
  • Draft saved Draft deleted
