Cali Dump Truck, End Dump, Bottom/Belly Dump Ops......
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Working Class Patriot, May 17, 2013.
  1. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,165
    Jan 17, 2008
    Wherever and Whenever...
    Are you guys prepped for the 2014 CARB regs?
  3. Colorado Road Rebel
    Colorado Road Rebel Bobtail Member
    Does anyone out there know how much PSI is behind the Gates of a Belly dump Trailer when clossed? I asl this because I was inside one cleanning it out and the pins for to keep the gates open broke and crushed my legs.
  4. Working Class Patriot
    12,683
    23,165
    Jan 17, 2008
    What does your air gauge read?
    My dumps both used Fifth-Wheel Lock pins to secure the gates.....What kind of pins did you use?
  5. Dieselgeek
    Dieselgeek Medium Load Member
    427
    209
    Nov 25, 2012
    Minnesota
    Ouch! Still have use of your legs?
  6. okiedokie
    okiedokie Road Train Member
    12,197
    90,666
    Jun 13, 2011
    PNWET
    Maybe the same as or less than your typical max pressure on the truck. I think the weight of the gates is what did the damage. Hope you recover soon.
  7. thePUNISHER
    thePUNISHER Medium Load Member
    564
    282
    Sep 20, 2009
    Merced, CA
    The gauge on the tanks for the gates on my truck usually read about 140psi give or take a few.
