cam position sensor 3406E
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gafred99, Dec 3, 2009.
  1. gafred99
    gafred99 Light Load Member
    155
    12
    May 28, 2009
    Tignall
    Is this the cam position sensor? CAT 3406E.
  3. BigSam
    BigSam Light Load Member
    220
    240
    Mar 23, 2008
    Illinois
    yes it is.........
  4. gafred99
    155
    12
    May 28, 2009
    Tignall
    is there a crank sensor? where?
  5. DDS
    DDS Medium Load Member
    519
    177
    May 20, 2008
    Toronto
    If its the same engine in the picture above, there is no crankshaft sensor. That engine is a 40 pin ecm. The dual timing sensors are used with the 70 pin ecm (99 and up)
  6. gafred99
    155
    12
    May 28, 2009
    Tignall
    yes same engine as in the pic, what other sensors do I need to know about? function and location wise.
    thanks,,,,,,,,,,,,,,,,
