can anyone tell me what is wrong with my DD 15 I'm currently on a run it's a 2 drop I was able to make it to my first one but when I was done getting unloaded I put it in low gear and accelerated she took off like normal but as I started to gain a little more speed the accelerated it started doing the exact opposite and started slowing down . Everytime I try to accelerate it would rev up while in gear so it was kind of pick up speed but then it would slow down like it would completely lose power for 5 seconds or so then it would rev up again and It would gain a little more speed but then lose acceleration power and that's all she did I couldn't even get it no more than 3 gear the whole time I had the pedal all the way down. I have three lights two check engine lights and one red. She gave me a few codes eec61 SPN 3361 and another spn5246 eec 6 1 can anyone tell me what is going on with the truck I have heard that you could be the doser valve or a sensor of the DPF when are you guys can just give me an idea where I could possibly look 2 at least get her going I would be very grateful
Can anyone help my puttering dd15
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by CDL CPL, Jul 17, 2018.
3361 indicates a power or wiring issue to you lr def pump, 5246 indicates the government shut down has been met.
More than likely you have a rubbed wire that is shorted or broken down around your def pump. After you find it and fix it. You might be able to get the gov code to deactivate by idling the truck for 5 minutes and shutting it off for 5.
Right now your truck is locked down to >5mph -
If there are no other active codes They must not have done a regen on it. It takes a successful parked regen or SCR conversion test to clear the government codes (5426). If they fixed the wire and did not do a regen then the government code can still be activated after 30 miles (still thinks it’s getting ignored). To give them the benefit of doubt, they might have hoped you would get a passive (driving) regen started and it would clear its self.
Or the mechanic was just lazy. -
Do a parked regen it takes about 40 minutes.
So is there any steps i can do to make it regen? Or leaving it on for 40 minutes should do it?
A DD15 will not do a manual Regen unless the light on the dash indicates that a Regen is required. Otherwise you need Detroit Diesel Diagnostic Link to initiate one.
