Can Anyone help?????
Discussion in 'Peterbilt Forum' started by noodler, Jun 26, 2012.
  1. noodler
    noodler Bobtail Member
    43
    13
    Jan 13, 2010
    Raleigh,NC
    I have a 06, 387 pete, C-15 CAT, after every pm I have to bleed the fuel lines as it seems to somehow gets air in the lines. Once i have done that, get down the road and start to pull on inclines my truck run very ruff and it does this for about 2 weeks...Its driving me nutts, not only do i hate getting pm's(cause their over priced) but i really hate them because my truck runs like crap afterwards......please help!!!...p.s I use all CAT filters...
  3. LBZ
    LBZ Road Train Member
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    Do you pre fill the filters before installing them? I do on mine & never had a issue, but have a older C12.
  4. noodler
    43
    13
    Jan 13, 2010
    Raleigh,NC
    yep , filled and all!!!!.....this is killing me....
  5. Turbo55
    Turbo55 Bobtail Member
    9
    I had this problem once, check all your connections and fuel lines. I saw peterbilt mechanic put a clear nipple in line to detect air bubbles. this was after several times in the shop. Replaced fuel lines, problem solved.
  6. QUALITYTRUCK
    1,810
    1,772
    Jun 14, 2009
    romulus,mi
    change pressure relief valve.screws into primary filter housing (1 inch fitting)about $40 CAT part.
  7. rockhead
    rockhead Bobtail Member
    8
    Aug 16, 2012
    Also check draw lines at tank, have known these fittings to lossen up and cause problems.
  8. rockhead
    8
    Aug 16, 2012
    Another problem that i've had. also, not sure which primary filter housing/filter you are using, but double check that if it uses an oring in the threaded housing, it is there, and vica versa, if it isn't supposed to use one, there isn't one there.
  9. noodler
    43
    13
    Jan 13, 2010
    Raleigh,NC
    thanks guys i'll check these out and give u guys an update
