Can I get my CDL with a recovered shoulder injury?
Discussion in 'Questions From New Drivers' started by hoovified, Jun 15, 2014.
  1. hoovified
    hoovified Bobtail Member
    13
    Jun 15, 2014
    Reading, PA
    Hello all,
    I hurt my shoulder last year at work. After over a year I finally got placed back onto full duty, for any job. I have not been employed since March and do not plan on starting school for a couple of months. I might get a part time job in between but right now that's kind of up in the air.
    Anyway, I'm getting off track. So I hurt my shoulder (which also messed up muscles in my back and hip), but have a clean bill of health now according to the doctor. Do I need to report the injury for my DOT physical? Will I still pass it if I do (assuming all other tests come out OK)? Will it make it harder or impossible for me to find a job in the trucking field?
    I know a lot of companies require physicals as well that require heavy lifting. I am currently working on strengthening my shoulder for the company tests.
    I just wanted some opinions before I go to school, etc. Don't want to get so far into doing it and find out it was all for nothing. If anyone has a similar situation, please share. Thank you all :)
  3. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    some jobs in trucking as easier then others
    i drive a reefer never load or unload
    no physical past DOT requirements
    less said the better at all times
  4. 8thnote
    8thnote Road Train Member
    1,980
    3,687
    Aug 12, 2013
    Chattanooga, TN
    I was in a car accident 18 years ago and injured my shoulder. I had to have tendons and ligaments reattached with pins (6 total), but miraculously had no rotator cuff injury. My first driving job was with a reefer outfit and I had no problems there. When I left that company, I tried to get on with a flatbed outfit. They sent me to their company doctor for the DOT physical, he saw the scar, and they disqualified me as a matter of company policy which doesn't allow you to have had any shoulder or back surgeries. I then applied to a dry van company, which I am still with now (I'm actually glad I didn't get that flatbed job now, as I'm very happy at the company I'm with).
    My injury was a long time ago and it doesn't give me much trouble. I don't have a full range of motion in that shoulder, but it's never been an issue as far as doing my job. So in summary, there is no DOT regulations that would disqualify you, but individual companies may have a policy that would.
  5. hoovified
    13
    Jun 15, 2014
    Reading, PA
    Thank you! I was mainly worried about the DOT physical. I definitely do not plan on doing flat-bedding... manual labor is not my favorite, especially since I injured my shoulder. I'll do it when I have to but would much rather not have to worry about touching freight or anything, I did enough of that stuff at my other jobs haha. Next question that I forgot to ask... do you think it will be a problem, me being out of work for 6 months or so?
  6. 8thnote
    1,980
    3,687
    Aug 12, 2013
    Chattanooga, TN
    it shouldn't be as long as you can provide documentation as to what you were doing and why you were unemployed during that time.
  7. TomOfTx
    TomOfTx Road Train Member
    1,190
    1,406
    Jul 13, 2013
    Friendswood, TX
    You will need to disclose the injury on your DOT physical since it occurred in the past 5 years. Just bring documentation from your doctor showing you were cleared to return to work. This always helps a lot because the doctor performing your physical likely does not know your medical history. It makes it easy for the doctor to make an informed decision.
    Most carriers do not go beyond the standard DOT physical, though jobs with carriers that require physical labor are the ones more likely to have you submit to a physical capability evaluation in addition to the DOT physical.
    In order to just obtain your CDL, a standard DOT physical is the most that will be required until you attempt to be hired by a carrier that may have addition physical requirements. Just stay away from any carriers requiring a lot of physical labor in addition to driving.
    Best wishes to you.
  8. Chinatown
    Chinatown Road Train Member
    74,669
    169,747
    Aug 28, 2011
    Henderson, NV & Orient
    There's some companies that have no-touch freight.
    Put your location on your profile so we know the hiring area you live in.
  9. Knucklehead619
    Knucklehead619 Medium Load Member
    537
    591
    Mar 11, 2014
    Flyover Country
    You may want to continue working on strengthening your shoulder more before going thru the process of looking for a driving job. I've worked for 2 large carriers (Swift and Crete) both of which require you pass both the basic DOT physical and some form of a "work well" evaluation where you're required to demonstrate safe lifting abilities, flexibility and dexterity. I remember 2 drivers getting sent home from orientation for failing his evaluation even after they passed the DOT portion just fine. Many other carriers have similar evaluations even though they (like my current and previous employers) are mostly or exclusively "no-touch" freight. In almost 8 years of driving I can count on one hand how many trailers I've unloaded but the possibility is there and most employers would rather see they're hiring drivers that are 100% physically qualified.
    In short, if you're not 100% recovered your best bet is to take more time or at the very least ask your recruiter what the requirements are for the company in question.
  10. bubbavirus
    bubbavirus Medium Load Member
    My arms are sore as hell from eight years of lifting luggage.
    Last week it finally happened, dropped a bag four feet when my good arm
    gave out.
    But I need the job for medical benefits.
  11. hoovified
    13
    Jun 15, 2014
    Reading, PA
    I am doing strengthening activities and making sure I do stretches and improve my flexibility. I know what is required for some of the trucking jobs. My ex used to work for Crete and I would often go with him for weeks at a time. I'm sure I can handle the no or low - touch jobs, but not sure about the job physicals at this point. Crete is one of the companies I would be considering. I just wanted to make sure that having a past injury doesn't automatically disqualify me, even if I pass the tests. Eventually I plan on setting up tests exactly like in the Crete physical video on YouTube, or maybe even add a little weight and a few more reps. But that's a while off. Thanks for all the answers and responses so far!
