Can you replace ATO2612D with a AT2612D I Shift Transmission?
Discussion in 'Volvo Forum' started by Siinman, Jan 13, 2022.
  1. Siinman
    Siinman Road Train Member
    5,243
    13,273
    Mar 5, 2017
    Kansas City, MO.
    Shop ordered the wrong part number and I am wondering if this will be an issue? Truck has 2.64 gears I shift 12 Speed. I am guessing it will fit fine but 12 speed will be a little higher on RPM?
    Anyone know how this will work out?
  3. Pow351
    Pow351 Bobtail Member
    It's two years late but here's an answer...
    Yes you can but...
    You will need to have the ECM parameters modified, so the ECM recognize the direct drive I-Shift.
    Because your Differential gear ratio is ar 2.64, you should have no issue with increased rpm. I installed a Direct Drive where an OverDrive was needed that's how I know!
    Because this truck has a 3.42 gear ratio, I'm doing 55 at 1550 rpm.
    Will re-installed an ATO in a few weeks.
