Can you tighten loose side skirts?
Discussion in 'Volvo Forum' started by ErieMcDreary, Jan 23, 2020.
  1. ErieMcDreary
    ErieMcDreary Medium Load Member
    455
    384
    Dec 4, 2016
    Erie PA
    VNL. The skirts are loose, is there a way to fix them? I tried pushing an old rag into the rubber bushing where the U shaped cut out on the skirt slides in, that worked pretty good, but I was thinking of something more permanent. Possibly something on the latch pin?
  3. Flat Earth Trucker
    3,735
    12,611
    Nov 19, 2018
    You must be referring to the fairings.
    My company 579 had loose fairings. I mentioned this to the service manager while at a dealership and he looked at it then informed me that the rubber bushings needed replacement, but that the repair cost would be under warranty.
    My company only had to pay for the parts and shipping.
  4. ErieMcDreary
    455
    384
    Dec 4, 2016
    Erie PA
    I was going to ask the dealer, just hadn't gotten there yet.
  5. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    If you are referring to the fairings under the passenger and drivers side the round rubber bushings on the bottom and the square ones on the top do wear over time. They are cheap and easy to replace, 2 wrenches(14 or 15mm, don't quote me) and you are done in 5 minutes. Don't buy the metal tube that the rubber spacers fit onto that the bolt goes threw unless you really need it. If you are meaning the fuel tank fairings then that is a pain. Do not take them off until you have the special metal fitting roughly half way from the front that tightens the fairing to the front fuel tank strap. Many volvo places do not stock them and special order them. It can take days. Unless you want to drive without the fairing on.
  6. ErieMcDreary
    455
    384
    Dec 4, 2016
    Erie PA
    Thank you much. I wasn't sure if the pin part of the latch was the issue or those bushings. I'll get those and replace.
    Thanks again.
  7. jlawall
    jlawall Light Load Member
    63
    15
    Jan 29, 2011
    wapwallopen pa
    yep. all those parts in that system do wear out due to vibration. For a top notch job replace rubber bushings, latch handles and pins.I think all those components come in a kit from Volvo. I'm not sure if the hard plastic parts that the pins enter are included but you'll want to replace those as well. I usually buy the bolts and nuts for those as they are quite lightweight and easier to snap off and replace than trying to save.
  8. ErieMcDreary
    455
    384
    Dec 4, 2016
    Erie PA
    Thanks, I'll look around for a kit. You don't have a part number, do you? I'm sure it'll be cheaper online.
  9. jlawall
    63
    15
    Jan 29, 2011
    wapwallopen pa
    Negative on the part #. Sorry
  10. Newto Trucking
    Newto Trucking Medium Load Member
    359
    225
    Dec 26, 2013
    NE Illinois
    85125440 on eBay also
    85109088
  11. ErieMcDreary
    455
    384
    Dec 4, 2016
    Erie PA
    Thanks, looks like what I need.
