Carrier 2500 x2 fuel leak
Discussion in 'Refrigerated Trucking Forum' started by kmbtrans22, Apr 3, 2022.
  1. kmbtrans22
    kmbtrans22 Bobtail Member
    Has anyone replaced the fuel lines from under the unit up to the fuel pump. I have a leak that im assuming is right there cause there's residue all over the motor and the framing etc. The red line is the supply and the black is the return im guessing. The schematics say there both brown. I would take it in to get it done. but I just got done spending 30k since january getting my truck all good from two breakdowns. Any info on this would be much appreciated.
  3. reeferwrencher
    reeferwrencher Medium Load Member
    490
    1,212
    Aug 4, 2018
    Clean the diesel off the engine with brakleen and start the unit you should easily be able to see where the leak is and repair
  • Draft saved Draft deleted
