I got one engine yellow light comes on for my Freightliner EVO 2016
And the code I found it by the diagnostic option SPN 3226 FMI 13
I'm not sure where is the problem with this code the one I have
Can I still drive the truck to finish the Load I still need to 2000 miles to go
I no feel the truck losing power so far
Cascadia 2016 code light
Discussion in 'Freightliner Forum' started by Mahertruck, Jul 22, 2019.
Looks like thats a voltage issue to the NOX sensor, I get those once in a while. It only take a split second of a loss or surge of power to set off a code and are generally harmless but may indicate there is a problem with a harness or maybe the ECU. See if you can clear the code and if it comes back. You should be ok to make your trip. Also did this code happen to pop up while it was raining?
The night before was okay after I finish my shift was no lightPE_T Thanks this. -
PE_T Thanks this. -
But what I do with code code showing on the dash board
SPN 3226 FMI 13 . I hope to know what the code means -
